Guest Mystical Posted August 30, 2009 Share Posted August 30, 2009 Hi, I have a 2JZ-GTE engine sitting in my shed that i have freshened up. Everything is standard but am going to go single turbo. I have purchased a single turbo manifold but having problems deciding on what turbo i should use and am having trouble reading some turbo calculation graphs etc. Any suggestions/Help would be much appreciated. Cheers Quote Link to comment Share on other sites More sharing options...
jevansio Posted August 30, 2009 Share Posted August 30, 2009 There have been some tried & tested setups but it depends on what you want big power or great response. A T67 is regarded as the best allrounder for a street setup (circa 600-650bhp). T71/T74 are if you require a bigger top end (650+), T61 if you want lightening response (500-500bhp). The Garret range of GT35R, GT40R etc have their rough equivalents to the above. Quote Link to comment Share on other sites More sharing options...
Guest Mystical Posted August 30, 2009 Share Posted August 30, 2009 Im looking for a street setup vehicle, Roughly around 500 - 600bhp. I was looking at the garrett GT35R range. I want the turbo to start coming online around 2000rpm and full boost at around 4000rpm. How do i choose the A/R etc? Quote Link to comment Share on other sites More sharing options...
JamieP Posted August 30, 2009 Share Posted August 30, 2009 T61 or T67 with a .68 AR will do the job, one of the new Precision billet 6262's will most likely be best, they are getting great reviews for spool and power. Quote Link to comment Share on other sites More sharing options...
Guest Mystical Posted August 30, 2009 Share Posted August 30, 2009 ok, Il look into those two turbos, cheers Jamie Quote Link to comment Share on other sites More sharing options...
imi Posted August 30, 2009 Share Posted August 30, 2009 Look up wez's ecu register to compare some setups. Quote Link to comment Share on other sites More sharing options...
