Advise/Help
Guest Genty
Having some issues with the supra and need your help.
When i select reverse gear the beep sounds and you can feel it select the gear however when you release the brakes it just dont move in reverse?
Also when you select Neutral it drives forward as if it is drive mode?
All fluid leves are topped up.
The triangle warning light is on above the rev counter and the circle warning light is on (The one near the temp gauge in right pod)
Its a 1994 Auto mk4 supra. Also does anyone know any VAT registered garages near Leicester i can take it to?
Im out and about but need help on this so if anyone has any can they possibly call me or text me what they think it could be.
07533361081 Thankyou!
