tarcase Posted August 30, 2009 Share Posted August 30, 2009 My manual N/A has started behaving like an automatic when putting away - in otherwords there is a slight time delay in the power kicking in, almost like the clutch is slipping - do you think the clutch is on its way out? Quote Link to comment Share on other sites More sharing options...
damouk Posted August 30, 2009 Share Posted August 30, 2009 sounds like the cluch has already gone not on its way out Quote Link to comment Share on other sites More sharing options...
b_have Posted August 30, 2009 Share Posted August 30, 2009 My manual N/A has started behaving like an automatic when putting away - in otherwords there is a slight time delay in the power kicking in, almost like the clutch is slipping - do you think the clutch is on its way out? Is it only when you're putting it away? Quote Link to comment Share on other sites More sharing options...
tarcase Posted August 30, 2009 Author Share Posted August 30, 2009 yes it seems to be only when pulling away. Quote Link to comment Share on other sites More sharing options...
Havard Posted August 30, 2009 Share Posted August 30, 2009 Is it stronger than your hand brake?? Also put in a high gear and try to accelerate on the motorway etc..!! H. Quote Link to comment Share on other sites More sharing options...
snake Posted August 30, 2009 Share Posted August 30, 2009 Put it in third gear with the handbrake on if it doesn't stall when you lift up the clutch pedal with some revs the clutch is fubar Quote Link to comment Share on other sites More sharing options...
nero Posted September 15, 2009 Share Posted September 15, 2009 Does the clutch slip at all during driving or when you floor it, that's also an obvious sign the clutch is done. How many miles/km's do you have on the current clutch Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 16, 2009 Share Posted September 16, 2009 It'll be needing a new flywheel or worse if you drive it with it slipping, which it certainly sounds like it's doing. Quote Link to comment Share on other sites More sharing options...
