How To Adjust Shared Ram
Scott
I'm a bit confused by my new laptop. It has 1gb dedicated gfx ram & can share a further 1gb of ram.
How do i adjust the amount of GFX ram is being used at any one time? Is it automatic? I've checked the bios and all the graphics properties i can find but i can't see any adjustment. I've always had dedicated gfx on my laptops but never where they are dedicated and shared.
If it helps my lappy is an Acer 6930g and the gfx card is the GeForce 9600m GT.
Thanks
http://www.nvidia.com/page/turbocache.html
I wonder if it's something to do with that. I read the 9600M 1gb can have up to 2303mb TurboCache. Presumably that means the GPU can use the TurboCache technology to draw on system memory when needed.
For instance if you were playing a graphics-intensive game, the technology might take 1gb of your system memory in order to boost its graphics capability.
If that's the case, because it's dynamic, I doubt you'll be able to change it manually - I would imagine the technology will decide when and where it needs the additional graphics memory. I would also imagine that unless you're playing a specifically graphics intensive game or application it won't draw any additional usage from your system's installed RAM.
