Can you diagnose this noise?
supspower
Ok ive got a noise coming from the engine bay im guessing its belt related? A pulley? It sounds kinda metallic i now its gonna be tough with the quality of sound but here goes....
ok so far thats the best i can do for showing the video unless someone can tell me how to add it so you can play it from this thread?? Hope this works ha! :)
Edited by supspower (see edit history)
Ok ill do the water test then if it stops ill change the belt if it comes back ill get the WD40 out....Actually scrub that...ill do the water test then the Wd40 test then ill decide what to do next depending on results :)
Though if anyone else knows for sure by all means type it down ;)
I'd be removing the drive belt and turn the idler/tensioner pulley by hand to see if it's OK, then do the same with the other 'driven' pulleys.
If no resolve, start the engine minus drive belt (for no more than 20 secs) and hear if the noise is still present.
Your water pump and fan wont be running, hence keep it short. You wont need the A/C, power steering or alternator.
You will probably notice if the noise is still there, in an instant.
Squirting crap on your belt wont do it any good and wont tell you excactly what the problem is.
Edited by Luigi (see edit history)
Mine ocassionally squeeks. I spray WD40 in behind the power steering pully and that fixes it.
That's probably the PAS pump bearing on it's way out. Mine did that and the WD40 trick worked up to the point where the bearing race ate itself spectacularly :)
Yes its fairly easy to fix, the hardest bit is getting the serpentine belt back on.
6203.2RSR is the bearing http://simplybearings.co.uk/shop/advanced_search_result.php?osCsid=cb74f8119abdd8171cc27dca7d5f8b9d&sort=2a&search_in_description=0&keywords=6203.2RSR+&osCsid=cb74f8119abdd8171cc27dca7d5f8b9d&x=16&y=12er (link to bearing supplier)
Take the pump out and split it remove the bearing and press a new one in, you'll also want to get a new seal kit from toyota. There is nothing to stripping them just be wary you don't lose any of the fins from the rotor when you split it.
