Guest RSjonny Posted November 6, 2009 Share Posted November 6, 2009 Good post - as an aside where was the "mapping centre in Halifax"? Mike It was The Racing Line (TRL) Quote Link to comment Share on other sites More sharing options...
DODGYDODDS Posted November 6, 2009 Share Posted November 6, 2009 A while ago I did a bit of research on this subject, I questioned numerous v-power fuel stations and also sent off numerous email to Shell UK. From memory, v-power in the UK was only slightly higher than normal premium fuels sold by the likes of esso and BP. Esso and BP premium fuel was 97RON and v-power (then called optimax), was 98RON. Optimax and v-power have always been different, like bp super unleaded to bp ultimate, two completely different formulas, or brands if you will. From memory v power has always been 99ron for the good few years it has been sold. They are probably putting 99 on the pump now, as V-power is 99 ron and they want to stand that fact out against the likes, of normal 97 ron supers and bp's 98ron ultimate. in a more expensive competitive market. This is a fifth gear article on it (optimax though not V-power) Where the fuels are tested on the dyno. Supras mentioned to dDHwCWdrtdg Optimax won, marginally but it is only benificial if you have a sportier engine Quote Link to comment Share on other sites More sharing options...
benkei Posted November 6, 2009 Share Posted November 6, 2009 This is a fifth gear article on it (optimax though not V-power) Where the fuels are tested on the dyno. Supras mentioned to Optimax won, marginally but it is only benificial if you have a sportier engine I watched this episode last week Hasn't that always been the case? I thought that was the point in the higher RON fuels, to help boost performance engines. If your engine isn't designed for performance, then the fuel will have no effect. Quote Link to comment Share on other sites More sharing options...
