Memory help - again!
CJ
I have been struggling to find suitable upgrade memory for my PC out here on Kos and finally had some delivered from DABS. I have gone to put it in today and both sticks are giving me the rapid beeps (i think that means bad memory) on power up.
The specs are as follows:
Processor - AMD Athlon XP2200+ 1667MHz
Motherboard - Soltek 75FRV
Hard drive - 186Gig (160 free)
Unknown memory 512mb
I tried the Crucial memory advisor thing and they suggested I could upgrade to 2 x 1GB sticks. I then bought these and had them shipped to Kos.
As I said, I have now tried both the sticks and they both make the rapid beeps but when I put the old memory back in, all is OK.
I have just noticed that the new ones are PC3200 and my old memory was PC2700 - would that make a difference?
All help greatly appreciated. :)
That is very strange :blink:
I have just used the Sandra SIS program to ascertain how much memory the motherboard can accept and it says that I have 4 memory slots with one being used and yet I know that there is definitely only 2 there!
The strange thing is, the Crucial program said the same too. I am very confused now :blink:
The spec of the Dabs stuff seems to match that recommended by Crucial, they list a 2700 and a 3200.
Have you tried the memory individually?
have you tried it in slot 1 and 3 rather than 1 and 2 (or 3 and 4)? 75FRV should have 4 slots.
Are you replacing a single 512mb or 2 x 256mb?
Is there a red LED visbile on the motherboard when the memory is inserted? Does it stay on when the new stuff is put in? (Indicates 2.5v feed to memory I believe).
Latest bios version?
Sounds like it could be faulty memory, anyone else who can test it for you in another machine?
What's the maximum memory you board can take? If you have 4 slots (this may sound a bit Neanderthal), but could that suggest that it takes 4 x 512 sticks rather than 2x 1gb sticks?
Yes and I get the beeps for both
As I said above, I only have 2 slots - unless I am being a complete numpty and not looking at a hidden area
A single 512mb
I have not checked that as i put everything back together before powering up - noob eh?
Unsure how to check if it is or not
I could take it to a local PC shop but somehow I don't think both would be faulty. I say that as almost all of the reviews suggest this is a very good make of memory and therefore for both sticks to be faulty would be quite surprising
CJ,
Take out the 512mb, replace this with 1gb and see if the system starts. If so; then proceed to install the 2nd stick (once the system has powered down) and then try again.
Try and refer to the Bios manual, you may need to make some Bios changes before adding memory.
CJ,
I have already done the changes as follows:
1. Taken out the old stick and put both new sticks in - beeps
2. Put one stick into the first slot - beeps
3. Put second stick into the first slot - beeps
4. As above but in the second slot - beeps
I just used AIDA32 and it came up with this:
Motherboard Properties
Motherboard ID 62-2000-001136-00101111-040201-KT600$6A6LYSAFREV AR1.3L
Motherboard Name Unknown
Front Side Bus Properties
Bus Type DEC Alpha EV6
Bus Width 64-bit
Real Clock 144 MHz (DDR)
Effective Clock 287 MHz
Bandwidth 2298 MB/s
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 180 MHz (DDR)
Effective Clock 359 MHz
Bandwidth 2873 MB/s
Chipset Bus Properties
Bus Type VIA V-Link
Bus Width 8-bit
Real Clock 72 MHz (ODR)
Effective Clock 575 MHz
Bandwidth 575 MB/s
And this for the memory:
Physical Memory
Total 511 MB
Used 399 MB
Free 112 MB
Utilization 78 %
Swap Space
Total 1247 MB
Used 598 MB
Free 648 MB
Utilization 48 %
Virtual Memory
Total 1758 MB
Used 998 MB
Free 760 MB
Utilization 57 %
Soltek - who the fuck are they!?! :lol:
Colin - more photos of the mobo please. HQ of any large words too.
I suspect the motherboard in Q does not support pc 3200 ram and will not drop the bus speed down. Either that or both RAM sticks are phucked.
I love crucial's scanner, very much cack sometimes.
Soltek - who the $#@! are they!?! :lol:
I really cannot see both sticks being kaput and am starting to think the motherboard is the problem. Now that leaves me with a PC that only has 512mb of RAM and 2 perfectly good 1gb sticks that I cannot use - buggernuts! :(
It may also be that your Mobo does not accept 1GB sticks....
If that's the case then I guess I have an option of a new MoBo or get a new PC built using the Crucial sticks I have already purchased?
As my CD writer is also playing up, it doesn't make sense to spend too much on repair upgrade and I will probably be better off going for new eh?
I will have to trawl web sites looking for prices as i am back in the UK on the 22nd for 2 weeks and could take back loads of bits then.
IIRC they are DDR Sticks? Its an old tech, and not worth building a new pc around them.
If you want an easy life, then go new. You have what looks to be a rather old PC there buddy. The other alternative is to get another 512MB stick and just be done with it. Try and match it to the same as what you already have.
Give us the motherboard brand and model and I can go delving. I cant make anything out from the pictures earlier in the thread.
You could always have a PC built/part built here and have it posted to you for when you hit the UK ;)
