SupraStar 3000 Posted April 26, 2005 Share Posted April 26, 2005 About three months ago a local garage fitted a new starter motor for me, then today I asked Toyota to change my oil and fit a new timing belt. The car was due for a service but to keep costs down I did some work myself like filters, engine cooler and brakes. Then Toyota call me and say the cam pulleys are loose and the tension bar cracked requiring new parts at £300 (£790 including oil change and fan belt) Question 1: would a mechanic need to go anywhere near the timing belt, cam pulleys or tension bar when removing and replacing the starter motor? Question 2: What would you expect to pay for a new timing belt including fittings, locking pins and tension bar? Cheers guys. All help appreciated Quote Link to comment Share on other sites More sharing options...
eyefi Posted April 26, 2005 Share Posted April 26, 2005 1. no 2. not sure on the labour and tension bar but belt is £22+ and crank pins are 60pish each Quote Link to comment Share on other sites More sharing options...
Homer Posted April 26, 2005 Share Posted April 26, 2005 Q1: No chance Q2: Not sure about the tension bar but my local (useless) Toyota garage charge £200 to change a timing belt (parts and labour inc) Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted April 26, 2005 Author Share Posted April 26, 2005 Cheers guys. Looks like I was a VERY lucky boy. God knows the problems I would have had if the timing belt had of snaped off or the pulleys bust Quote Link to comment Share on other sites More sharing options...
dude Posted April 26, 2005 Share Posted April 26, 2005 Cheers guys. Looks like I was a VERY lucky boy. God knows the problems I would have had if the timing belt had of snaped off or the pulleys bust Not a lot really except an AA ride home Dude PS out of interest ask the Toyota garage what would have happened and post the answer here Dude Quote Link to comment Share on other sites More sharing options...
Digsy Posted April 26, 2005 Share Posted April 26, 2005 Then Toyota call me and say the cam pulleys are loose and the tension bar cracked requiring new parts at £300 (£790 including oil change and fan belt) Hold on a sec... The oil change will be next to nowt (or sub £100 in Toyota-speak). The pulley and tension bar job is £300 A new FEAD belt (don't call it a fan belt) is £80 for a genuine Toyota one. Fitting the FEAD belt is a zero-labour job as is has to come off when they do the cam belt anyway. ...so where the hel does £790 come from? Quote Link to comment Share on other sites More sharing options...
dude Posted April 27, 2005 Share Posted April 27, 2005 They could mean the tension bar for the drive belt , this is quite expensive . Dude Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted April 27, 2005 Author Share Posted April 27, 2005 think it must be the tension bar for the drive belt. I'll go and talk to them tonight after work Got a few questions myself regarding cost and parts Quote Link to comment Share on other sites More sharing options...
Digsy Posted April 27, 2005 Share Posted April 27, 2005 Ah - I thought the tension bar was included in the £300. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted April 27, 2005 Author Share Posted April 27, 2005 Picked up the car and I must admit she purs again without that asmatic rattle. Heres the bill: 42.00 - oil & Filter Change 270.00 - Replace timing belt ------ - Replace fan belt ------ - Replace crank pully and woodruff key ------ - Replace crank pully bolt ------ - Replace timing pully & timing woodruff key ------ - Replace tensioner 51.00 - ESSO ultron oil 177.37 - crankshaft pull 36.79 - pully shaft 49.57 - chain tensioner 28.83 - timing belt 4.84 - bolt 0.71 - key, wooddruff 0.71 - key, wooddruff 0.76 - drain plug 7.39 - oil filter £669.97 Net £117.2 Vat £787.21 Total Quote Link to comment Share on other sites More sharing options...
eyefi Posted April 27, 2005 Share Posted April 27, 2005 ahhh, so it was the crank pully that was loose, not the cam pulleys. i thought it was a bit strange that the cam pulleys would be loose. that's a big bill though they did forget to bill you for the thread lock adhesive though did the loose crank pulley cause any damage to the end of the crank, specifically the keyway? Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted April 27, 2005 Author Share Posted April 27, 2005 no. I asked and the mechanic said the crank was ok. Good job too because that would have cost a fortune to replace. I also asked to see all the original parts and have taken the home with me. The damage is evident on the defect parts so I guess I have been lucky although its cost me a bomb to fix Quote Link to comment Share on other sites More sharing options...
JohnA Posted April 28, 2005 Share Posted April 28, 2005 Not a lot really except an AA ride home Dude PS out of interest ask the Toyota garage what would have happened and post the answer here Dude I take it that it is not an interference engine then, eh? nice to know Quote Link to comment Share on other sites More sharing options...
Digsy Posted April 28, 2005 Share Posted April 28, 2005 So was it the crankshaft FEAD belt pulley that was loose, or the crankshaft timing belt sprocket? I'm still confused Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted April 28, 2005 Author Share Posted April 28, 2005 So was it the crankshaft FEAD belt pulley that was loose, or the crankshaft timing belt sprocket? I'm still confused err,.. crankshaft FEAD belt pulley any how, its fixed and I'm broke Quote Link to comment Share on other sites More sharing options...
