Standard Brake Discs - Sizes?
michael
I know the basic sizes are as follows:
Fronts:
296mm or 323mm
Rears:
307mm or 324mm
Does anyone have any additional size info on them?
For example the widths of each part, internal sizes of the rear drum section and so on?
Going off the little bit of info I've found so far the front 296's seem to be 32mm wide on the actual disc part, the 323's are apparently 30mm. On the back the larger disks are supposed to be 21mm but this is about all I can find - is there a complete spec up anywhere?
Thanks in advance to anyone with a set of discs and a tape measure :who:
