laptop spec question
Trig
can anyone tell me if my laptop will play this game?
spec needed for game -
Microsoft® Windows® XP SP2 / Vista
PC with 2 GHz equivalent or higher processor
1 GB of system RAM
4 GB or more of available hard disk space
DirectX 9 or higher compatible video card required
128 MB video RAM or higher, Shader Model 1.1 or higher
Sound card, speakers or headphones required for audio
Mouse or compatible pointing device
56.6 Kbps or better modem for online play
Laptop spec
Packard Bell EasyNote SJ51
Product details
RAM / Installed Size: 2048
OS Provided / Type: Windows Vista Home Premium
Storage / Type: Hard drive
Storage Hard Drive / Capacity: 160
Display (Projector) / Max Resolution: 1440 x 900
Optical Storage / Type: DVD±RW Double Layer
Processor / Type: AMD Turion
Processor / Clock Speed: 1.8
cheers :cool:
Have you got any more info on you graphics card for your laptop
:yeahthat:
I think the AMD Turion is a dual core 64 processor so should more than meet the requirements, however as always the graphics chip and whether it's integrated will be the key to performance and whether it meets specs.
think it is a NVIDIA GeForce Go 7000
If it's a 7000m model it more than meets the requirements. It's a 3.0 shader model and judging by the min specs will be great for whatever is in mind.
On the other hand it's an old and outdated setup and not what you'd call future proof :Pling:
ok cool, so i assume it would be ok for the flight sim?
its a game im thinking of buying, Flight Sim X.
im pretty sure it will run on my parents pc but was just wondering if it would run on my laptop as well. was more worried about the processor being 1.8 and it requires 2ghz?
Processor speed itself makes no difference these days, it's all about the model and spec. I have a high end PC but FS X still run like a dog on it :( It needs massive ram and video memory (4GB RAM and 512MB graphics didn't cut it)
If you're not sure how to use Torrents, don't bother with Pirate Bay :) It's also not strictly legal to download programs you're meant to pay for ;)
Your laptop has a 1.8ghz Turion chip, the game requires a 2ghz. That's a bit misleading though as the Turion chips are dual core, meaning you effectively have two processors - not quite the 3.6ghz it would seem, but significantly better than a 2ghz single core chip.
Flight sims are usually relatively RAM-hungry but your laptop has double the recommended spec. Similarly your graphics card should have more than 128mb RAM so I'm fairly sure it'll play well enough.
Hi Trig,
Yes it will run :) ....... but like a bag of shit.
Flight Sim X is a hugely graphics intense game, even if you had the top GeForce Go 7XXX card it will still struggle. By all means, give it a go but I think you will be hugely disapointed with how it looks.
If you are wanting top play games on a lappie then you need £1K upwards worth of hardware. Alternatively, build a gaming PC for under half that.
EDIT - http://209.85.229.132/search?q=cache:RS4oB3M744gJ:forum.notebookreview.com/showthread.php%3Ft%3D216380+GeForce+Go+7000+flight+sim+x&cd=6&hl=en&ct=clnk&gl=uk&client=firefox-a
