Guest chris080982 Posted August 21, 2009 Share Posted August 21, 2009 Hello, I want to remove the fog light that hangs from the rear of the car. Is someone able to paste the link for the modification to put the fog light in the rear lights for me as i cannot find it for some reason!!! cheers Quote Link to comment Share on other sites More sharing options...
dukenukem Posted August 21, 2009 Share Posted August 21, 2009 Here's one I found a while ago when my fogs went and I failed an MOT. I sent it to the garage but I don't know if they used it or not to fix them.Fog Lights.pdf Quote Link to comment Share on other sites More sharing options...
Al Massey Posted August 21, 2009 Share Posted August 21, 2009 Heres a few for ya mate http://www.mkivsupra.net/vbb/showthread.php?t=80479&highlight=fog+light+mod http://www.mkivsupra.net/vbb/showthread.php?t=144095&highlight=fog+light+mod http://www.mkivsupra.net/vbb/showthread.php?t=135794&highlight=fog+light+mod Quote Link to comment Share on other sites More sharing options...
Guest superdave Posted August 30, 2009 Share Posted August 30, 2009 The mod with the two diodes works fine and is very simple, no need for a mass of relays and resistors that give off loads of heat! It depends if you just want one fog or 2, but it just needs 1 diode put in the green/white wire to the inner brake light, this has the bar on the diode pointing to the bulb, then put another diode in the line fron the fog light switch. Both diode ends with the bar on the package are twisted together, as in the diagram on the link, then cover the diodes with insulation tape or heatshrink. If you want an nearside fog, then do the same as of the offside. The result is no heat given off while the fog lights are on, and the bulb failure sensor is happy. The diodes I used were 90SQ040 Schottky diode, radio spares 544-6085, they are 9A 45V parts, they drop 0.4V at 9A so there will be next to no visable difference in brightness between the seperate brake bulbs.:D Quote Link to comment Share on other sites More sharing options...
