Removing heater system sender pipe in engine bay
hadyn
Hi all,
I think the stock rubber heater sender hose which I've blocked off in this pic on the right, has sprung a slight leak:
My question is, what is securing this hose to the block? I cant seem to see any form of clamp or clip when I put my hands around it. Does it just pull off or is it actually secured to the engine in some way?
Your advice will be gratefully received as I dont want to start pulling at this pipe and damaging something...
i think i can feel the spring clip at the back - how much of a bitch is this to remove and reinstall?
Bit of a PITA, but can be done. Some helping hands would be advised ;)
How come you have it blocked off? Are you aware that's a bad idea?
I thought blocking off was the preferred solution?
was advised by multiple people on here that it is the best
Could have got this wrong, but I always understood it was best to place a narrower gauge link between the two so that not all water flow was forced through the block (i.e. sort of replicating the stock coolant flow levels). There's been a few cars that have blown their HG's while running these blocked off, so the assumption was that it could be caused by the heater matrix bypass.
Has been debated a few times and no real consensus has happened. I'm a fan of the blocking off or at the very least a restriction. Bear in mind the original matrix valve will just shut it down.
The few that I've heard of with blown HG's have always just been joined with a bit of pipe with no restriction.
I really cant see how bypassing the heater matrix can cause a head gasket to go, in fact it doesn't make any sense, no flow or full flow, which in effect is what the heater control does, can in no way influence the cooling system,(unless you already have an overheating problem) as the thermostat an rad control the overall engine temp, and the matrix is just a sub flow to the main circuit.
It's a bastard of job. The spring clips take some serious pressure to get them opened up. I found I could get to the clip with some long nosed pliers but I couldn't get adequate power/leverage to hold the clip open long enough to pull the pipe off with my spare hand.
I think I eventually closed the clip with pliers just enough, and just long enough, to get some mole grips clamped on it. And then it's still a struggle to pull the pipe off! Just the rubber hose on its own has some serious grip on the pipe.
Just take your time and try not to get annoyed with it (easier said than done in my case). You'll get there.
IIRC, on mine, one of those clips (ones onto heater matrix side) had an outer clip on too (bit like a double clip) which was a particular buggar to get off, I did it in the end by removing the outer clip first ('bout an hour with various tools & bleeding hands at end), then removing the sprung clip was easier HTH
Are these pipes known to fail or could it be down to the build up in pressure of having it blocked off?
The pressure in the pipes would be no different, should be around 0.9bar if you are running a standard rad cap. Given their age, I wouldn't be too surprised if they are getting weak.
They are a pain to get off, but i can't remember having such a bad time with mine, i took all of the pipework off and junked the spring clips in favour of stainless hose clips, and i also got rid of the std metal pipes, and made up some rubber (but with metal inside to form them) and got the whole lot looking really tidy, so you can't really notice them any more, will try and take some pics.
