Help Electric windows not working!!
j1mb0b1
Hi,
All i'am getting is a buzzing sound from the window control switch unit down on the door pod, and the windows will not go up or down and its the same on both windows, I have got a replacment control unit to try and that is doing the same, I have also check all the fues's.
Also some times for what ever reason they will kick in and go up and down, Sometimes just down and wont go back up, sometimes they will go up and down a few times ok then they just stop working again. its all very strange
Any ideas ??
Thanks guys !!
Yeah, mine went a few weeks ago on the drivers and when i took it out the wire had snarrled up in the coil.
Best off getting a new window winder regulator, altough they are hard to come by at the moment for some reason (second hand)
P.s, if you stop trying to get it to go up and down you might be able to salvage it. But if the wires a snarrled at all then they are lost. They won't wind up again properly.
  • 3 weeks later...
