Barney Posted August 20, 2009 Share Posted August 20, 2009 What is the easiest way to re-size pictures using Vista? When I had XP I downloaded the Windows Power Tools image re-sizer, it was nice and simple and worked great, can't seem to find the same thing for Vista. Quote Link to comment Share on other sites More sharing options...
Scott Posted August 20, 2009 Share Posted August 20, 2009 Right click on the image and then click on "edit". That will open up the picture in paint. You can then go to "image" then "resize/Skew", select pixles and choose the size you want. I normally go for 1024 wide. It automatically adjusts the height for you. HTH Quote Link to comment Share on other sites More sharing options...
Jamesy Posted August 20, 2009 Share Posted August 20, 2009 i just open it, click edit, resize and half the width and height or set to 50% Quote Link to comment Share on other sites More sharing options...
Scott Posted August 20, 2009 Share Posted August 20, 2009 i just open it, click edit, resize and half the width and height or set to 50% Depends on your camera settings. My camera takes pictures that are over 4000 pixles wide. Hitting 50% would still make them over 2000 pixles wide which is massive. Your camera perhaps takes 2000 pixle wide photo's so hitting 50% works fine. It won't work for most people though Quote Link to comment Share on other sites More sharing options...
Jamesy Posted August 20, 2009 Share Posted August 20, 2009 Lol. Ok Quote Link to comment Share on other sites More sharing options...
benkei Posted August 20, 2009 Share Posted August 20, 2009 MS Paint FTW. Quote Link to comment Share on other sites More sharing options...
JustGav Posted August 20, 2009 Share Posted August 20, 2009 http://www.irfanview.com Handles pretty much EVERY image type going. Quote Link to comment Share on other sites More sharing options...
Barney Posted August 23, 2009 Author Share Posted August 23, 2009 Guys, many thanks for your help. I have been using Scott's suggestion and that is doing a fine job. Quote Link to comment Share on other sites More sharing options...
Todd Posted August 23, 2009 Share Posted August 23, 2009 http://www.rw-designer.com/picture-resize fantastic wee program and without opening a photo editing suite it's the easiest method I've come across for batch resizing Quote Link to comment Share on other sites More sharing options...
Branners Posted August 25, 2009 Share Posted August 25, 2009 Jake found me a Vista resizer recently, I think it came from sourceforge. Do a search on here and it may turn up. It was a direct copy of the image resizer power tool but done by somebody else and not MS. Quote Link to comment Share on other sites More sharing options...
