Help setting up a HKS EVC IV Boost Controller.
Kevin Huntley
I have had a HKS EVC IV boost cotroller fitted and I was wondering if any of you guys could gave me a hand with the settings.
I have set the stock boost to 0.9 bar as that's all I can seem to get out of it while running the third gear test despite having a de-cat and FCD.
Having found the stock boost I have set the controller as follows, Low boost 0.9, High boost 1.1, Scramble boost 0.10 (1.2bar) which is set to 30 seconds and I have set the warning to 1.3 bar. The only problem I have is setting up the offset mode.
What have you lot got for your setting's and in particular what is your offset set to.
Cheers
