Looking for AVS Model 5 Wheels
ellis
Hi all - new to the Forum, new to Supra ownership! Had a BMW 325i coupé but decided time was right to get a car I've lusted after for a long time and I'm not disappointed. OK, so its only a N/A, but its still great fun - TT one day maybe! OK, reason for post - one of my front wheels has a slight buckle (apparently) - they're AVS Model 5s and I'm really after 2 but I can't find any suppliers on the web. Any of you guys got any contacts or ideas? Any help greatly appreciated! Pic of car attached too!!http://www.ellisgrange.co.uk/images/supra.jpg
I took it in to Kwik Fit to try and balance out a bad wheel wobble (only had the car 2 days!) and he showed me it bouncing slightly on the machine. They balanced the wheels and tracked them as best they could but the wobble is still there - worse at higher speeds. Where did you get your rims from?
Guest suprawannabe
nice motor can I ask what you piad ofr it as am after a soop and am having to consider getting an N/A now as also need to upgrade the other halfs motor so I can get one !
Have found a supplier for the AVS Model 5s - only £396 per corner! MVK2s are £125 a piece - just need to find out if the finish is the same and if I can use the cap from the AVS wheel on the MVK2. Apart from that, anybody know of a good wheel refurbisher who can straighten out a kinky wheel?!
how do you know its buckled??
MVK2s are a good copy of that advan rim - I used to have a set on my old 200SX:
Another questions then mate - if I replace the AVS front wheels with 2 MVK2s, do you think I can use the AVS centres? They're held on with small Allen screws which I'm assuming the MVKs aren't (could always use the MVK centres as a base for the AVS centres?)
  • 7 years later...
