Paul372 Posted August 18, 2009 Share Posted August 18, 2009 Hi, i'm getting a clicking sound from the front brakes when applied and my brakes are also juddering which i think is down to warped discs. I think its the rear ones that might be warped because they are quite old and i haven't changed them since i've owned the supe and the discs on the front i only replace them about 6 months ago with 3g discs and endless pads. I've looked at the brakes and all the shims are still in place and the pistons and seals on all the brake calipers look ok and they move freely so there all ok and not seized or sticking, what else can i check for any ideas and where abouts are the abs sensors i might give them a clean up Pics Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 18, 2009 Author Share Posted August 18, 2009 while i was under there i also tighten up front sub frame bolts but they did not move abit so there all good Quote Link to comment Share on other sites More sharing options...
edge Posted August 18, 2009 Share Posted August 18, 2009 Try and tighten up the lower wishbone bolt also as these come loose and cause a clonk/click when braking. Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 18, 2009 Author Share Posted August 18, 2009 Ha i think i might have found a problem, on the drivers side caliper the lower pin on the caliper with the arrow pointing to it on the picture is that surpose to move in and out if so the drivers side one don't, can you replace these Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 18, 2009 Author Share Posted August 18, 2009 Try and tighten up the lower wishbone bolt also as these come loose and cause a clonk/click when braking. i'll have ago at tighten them up tomorrow then thanks Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 18, 2009 Author Share Posted August 18, 2009 sorry forgot the pic Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 18, 2009 Share Posted August 18, 2009 Yes mate, they are supposed to be free to move in and out to apply pressure to both pad when you apply the brakes. I am sure you can replace them but I'd just try to free it up first. Remove the rubber boot, clear any gunk you can out of the way, get some good penetrating spray and apply liberally to the rod. I'd advise you to remove your pads before you do this to avoid contaminating them. Leave the fluid to soak in for a while and then start wiggling! It might need some more direct persuasion, but don't damage the thread hole if you do resort to a few taps of a hammer. Should all go according to plan and it frees up use a small amount of copper grease on the rod to keep it free then make sure your brake disk if free of any oils or grease before you reassemble. Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 18, 2009 Author Share Posted August 18, 2009 ok thanks for that mate i shall give it ago, the inner nut does'nt move at all has well Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 18, 2009 Share Posted August 18, 2009 Which nut are we talking about Paul? Is it under the rubber boot? Quote Link to comment Share on other sites More sharing options...
Dave Posted August 18, 2009 Share Posted August 18, 2009 just done this on my rears the pin was stuck in so managed to pull it out cleaned out the hole rubbed down the pin with fine wet/dry re greased now works fine Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 18, 2009 Author Share Posted August 18, 2009 the inner one next to the rubber boot Quote Link to comment Share on other sites More sharing options...
Paul372 Posted August 26, 2009 Author Share Posted August 26, 2009 what a pita trying to free that pin up it was well stuck but with abit of patience i finally got there, it started to turn then with a few taps i got it moving in and out so i clean it up and greased it sorted feels better, now i just have to find where that clonk is coming from Quote Link to comment Share on other sites More sharing options...
