Pete Posted April 25, 2005 Share Posted April 25, 2005 My cat was starting to make some dodgy noises and the car generally lost power so I took it to see Dr Wilson. He confirmed my suspicions that the 1st cat was buggered (split) so I opted for a decat pipe. Chris makes these pipes with his own fair hands and they look fantastic, far more than just a piece of pipe! (pic attached) Whilst we were at it the second cat flange was slightly damaged so they both got dumped. As a result of decatting the car seems slightly more responsive and has a little more poke. It definitely sounds "raceier" too without being too intrusive. A heartily recommended solution to dying cats. Many thanks to Chris Wilson who has made a professional job as ever. Pete Quote Link to comment Share on other sites More sharing options...
Ian W Posted June 29, 2005 Share Posted June 29, 2005 anyone know what 'the law' is when it comes to de-catting and what happens when it comes to MOT time?? i've got a '94 NA if that helps. cheers guys. Quote Link to comment Share on other sites More sharing options...
Oddball Posted June 29, 2005 Share Posted June 29, 2005 Not to sure..I think pre 92' cars don't require CATs for MOT's. My old 3 ltr Carlton 24v was on a 90' plate, de-catted and was fine at MOT time. Quote Link to comment Share on other sites More sharing options...
SatSport Posted June 29, 2005 Share Posted June 29, 2005 thought it was cars over 10 years old? Quote Link to comment Share on other sites More sharing options...
Pete Posted June 29, 2005 Author Share Posted June 29, 2005 It was definately a year. Either 92 or 93, can't remember which, in which case it just has to meet the emissions (which are allowed to be higher). There's another year where it's a simple visible test for black smoke. Quote Link to comment Share on other sites More sharing options...
suprz_rz Posted June 29, 2005 Share Posted June 29, 2005 Co limits for supra TT is 0.3 and mine went though with both cats out at 0.4, so removing only one cat will be no problem getting though MOT. Considering Co limits for pre cat cars is in the 3-4 region, 0.4 isnt half bad. Quote Link to comment Share on other sites More sharing options...
Guest chiefvinso Posted June 29, 2005 Share Posted June 29, 2005 Im sure its pre 92 cars that dont require a cat, just checking with VOSA. Did you know they can do a roadside emission test and server a prohibition notice if you fail and if it fails badly they wont let you continue your journey. Quote Link to comment Share on other sites More sharing options...
Pete Posted June 29, 2005 Author Share Posted June 29, 2005 Im sure its pre 92 cars that dont require a cat, just checking with VOSA. Did you know they can do a roadside emission test and server a prohibition notice if you fail and if it fails badly they wont let you continue your journey. Yup. Quote Link to comment Share on other sites More sharing options...
Guest chiefvinso Posted June 29, 2005 Share Posted June 29, 2005 The visual tests are for cars registered before 1 aug 1975 if I read it correctly and after that its a probe jobby unless its a diesel Quote Link to comment Share on other sites More sharing options...
AeroMatt Posted July 1, 2005 Share Posted July 1, 2005 Here is the flowchart for which cat test is required for the MOT. My car being an 94 NA (not in their book as ts an import with no UK equivalent) would need the non cat test. At my last MOT my double decatted supe wuld have passed the cat test comfortably anyway! Quote Link to comment Share on other sites More sharing options...
Pete Posted July 1, 2005 Author Share Posted July 1, 2005 That's great Matt. Quote Link to comment Share on other sites More sharing options...
John_M Posted July 1, 2005 Share Posted July 1, 2005 Need to refit cats on mine at MOT time as COs reading are just too high. No problem though as Leon keeps a set for just this purpose! My car being an 94 NA (not in their book as its an import with no UK equivalent) would need the non cat test. Think just about anything could pass on these levels! Quote Link to comment Share on other sites More sharing options...
Pete Posted July 1, 2005 Author Share Posted July 1, 2005 My car being an 94 NA (not in their book as ts an import with no UK equivalent) would need the non cat test. I guess the VVTi TT would be the same then too? Quote Link to comment Share on other sites More sharing options...
JustGav Posted July 1, 2005 Share Posted July 1, 2005 Hmmm, there might be hope for my VVTi fully decated beast then... *grin* Thought I might have to get creative with the MOT testing.. Gav Quote Link to comment Share on other sites More sharing options...
IDO Posted July 1, 2005 Share Posted July 1, 2005 AeroMatt.. mines a 93 N/A import.. would mine not need a cat test? i assume mine would fall in the same group as yours? sorry new at this decating thing... Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 1, 2005 Share Posted July 1, 2005 I'd like to know as my cars a 93 N/A import and want to de-cat soon as Quote Link to comment Share on other sites More sharing options...
Guest Daniel H Posted July 1, 2005 Share Posted July 1, 2005 hang about guys I have a good contact that can help clear this up. Give me five minutes. Quote Link to comment Share on other sites More sharing options...
Guest Daniel H Posted July 1, 2005 Share Posted July 1, 2005 Here we go.... from the MOT uk database. http://www.motuk.co.uk/exhaust_emmissions.htm This is the diagram garages should be using if they cant find a match for any import. So looking at that mate a 93 would have a non cat test. Print this out and take it with you on the day. Quote Link to comment Share on other sites More sharing options...
TrickTT Posted July 1, 2005 Share Posted July 1, 2005 Here we go.... from the MOT uk database. http://www.motuk.co.uk/exhaust_emmissions.htm This is the diagram garages should be using if they cant find a match for any import. So looking at that mate a 93 would have a non cat test. Print this out and take it with you on the day. Was talking to a mate who is an MOT tester earlier this week and he agrees with the above link for imports but said that the CO limits for the basic non cat test are being lowered soon "to harmonise us with EU limits" NICE!!!!!!!!! Basically he reckons even old cars, that came as standard without a cat, will probably need one retrofitted come MOT time. Quote Link to comment Share on other sites More sharing options...
Pete Posted July 1, 2005 Author Share Posted July 1, 2005 said that the CO limits for the basic non cat test are being lowered soon "to harmonise us with EU limits" Yeah right - I can see my kitcar liking that one! Quote Link to comment Share on other sites More sharing options...
