Blitz i-colour boost controller setting
a98pmalcolm
Hi guys, im sure there will be alot of eye rolling when you all see this thread as there as been so much dicussion b4 about these boost controllers with the crazy amount of functions lol.
Ok issue am getting is that i cant get over 1 bar of boost but i used to always run over!
I may have pushed the wrong button recently when changing views etc.
Just wondering what every1's boost settings are?
I have a Jap spec BPU
Thanks
Paul
Edited by a98pmalcolm (see edit history)
Which settings have you recently been altering?
Just thinking that if you have increased your boost recently and now you find that it has dropped significantly then maybe your system has developed a leak.
Either a hose on its way off, a split in a pipe or a leak in your intercooler.
Just changing views would not change the boost settings, you have to go into the boost menu and turn the dial and then accept the new setting etc.
ie. you would know about selecting a new boost setting.
Even if you havn't knowingly changed the boost setting a leak in the system can occur at any time.
