supra steveo Posted August 17, 2009 Share Posted August 17, 2009 (edited) well after rounding one of the bolts off i went and stripped the interior today, and replaceing rounded off nuts isnt really that hard so part number 90901-09004 price - £5.00 each bolt step 1. remove drivers pillar by pulling it coz its only clipped on step 2. remove OMG handle ( x2 screws) and pull off passenger pillar step3. remove the sun visors ( x3 screws) and u have to pull the little clip at the end hard or lever it out , dont be scard i wont brake ( well it shouldnt lol ) step 4. remove the interiorlight cover with a flat head screwdriver and the n the 2 screw inside to unfix it from the body of the car then unclip it step 5. remove the roof trim, it will come off easy step 6. then u will see what is in picture one so if u have rounded the nut off remove the cover by undoing the small screw and slide off the top cover , whats in picture two u can now go ahead and get a chissle and bash the living day lights out of it with a hamer anyway what u will get out is picture 3 so now go to toyota and get some new ones step 7. put it all back together jobs a gud un lets hope its sunny tomorrow hope this helps people use this link for the center bolt http://www.mkivsupra.net/vbb/showthread.php?t=120873&highlight=middle+bolt . Edited August 18, 2009 by supra steveo (see edit history) Link to comment Share on other sites More sharing options...
Al Massey Posted August 17, 2009 Share Posted August 17, 2009 Bout time you got round to this Link to comment Share on other sites More sharing options...
deathmonkey Posted August 17, 2009 Share Posted August 17, 2009 Nice one Steve, I'll keep this topic in mind. Cheers! Link to comment Share on other sites More sharing options...
AndrewOW Posted May 31, 2012 Share Posted May 31, 2012 Some threads can never die! As I need to replace one of my bolts now, this guide is invaluable. Link to comment Share on other sites More sharing options...
Matt H Posted May 31, 2012 Share Posted May 31, 2012 The rear bolts are built into the roof, so replacing them is far from easy. Link to comment Share on other sites More sharing options...
AndrewOW Posted May 31, 2012 Share Posted May 31, 2012 Yes, I know, but at least I've only got to change the front bolts in the main car body. I could fix the interior light problem I've got at the same time, once I've got the fascia off. Link to comment Share on other sites More sharing options...
supra steveo Posted May 31, 2012 Author Share Posted May 31, 2012 Some threads can never die! As I need to replace one of my bolts now, this guide is invaluable. Cheers Andrew glad to have been of help Link to comment Share on other sites More sharing options...
Matt H Posted May 31, 2012 Share Posted May 31, 2012 (edited) Here's the roof assembly from the parts guide. I purchased part 63296B as well when I bought new bolts from Toyota. Haven't a clue what they do though. I can only imagine they sit in the bolt holes when the roofs off? Edited May 31, 2012 by Matt H (see edit history) Link to comment Share on other sites More sharing options...
AndrewOW Posted May 31, 2012 Share Posted May 31, 2012 I remember having some little caps to go over the bolts when the roof was off, so maybe that's what they are? The rattle you get when the bolt gives way is shocking! What a noise! It sounds like the car is being shaken apart! Link to comment Share on other sites More sharing options...
Matt H Posted May 31, 2012 Share Posted May 31, 2012 I remember having some little caps to go over the bolts when the roof was off, so maybe that's what they are? The rattle you get when the bolt gives way is shocking! What a noise! It sounds like the car is being shaken apart! That's what I thought they were too, but rather pointless. What happened with me was when I was putting the roof back on. I threaded the bolt and it got stuck in there. was a bit of a nightmare getting it back out. Link to comment Share on other sites More sharing options...
AndrewOW Posted May 31, 2012 Share Posted May 31, 2012 (edited) Ooh that sounds very nasty. I remember you asking about the roof a few years ago, and that must've been the trouble you were having. I took a quick photo of the offending bolt. The shiny thread area is where it's worn off, and the darker bit at the bottom is all that is left of the thread! Edited May 31, 2012 by AndrewOW Better photo (see edit history) Link to comment Share on other sites More sharing options...
AndrewOW Posted June 1, 2012 Share Posted June 1, 2012 Job done, and what an easy task that was. Link to comment Share on other sites More sharing options...
supra steveo Posted June 1, 2012 Author Share Posted June 1, 2012 All sorted then time to wait for the sun to come out Link to comment Share on other sites More sharing options...
AndrewOW Posted June 1, 2012 Share Posted June 1, 2012 The sun has been out. Lots. It's now I have to put the roof back on for autumn was the reason why I had to get this done. Link to comment Share on other sites More sharing options...
supra digsey Posted July 26, 2012 Share Posted July 26, 2012 whats the part number for the rear bolts? also do they come with the springs? did you order these online? thanks michael Link to comment Share on other sites More sharing options...
supra steveo Posted July 27, 2012 Author Share Posted July 27, 2012 check out post #9 Link to comment Share on other sites More sharing options...
hazza Posted December 13, 2012 Share Posted December 13, 2012 The rear bolts are built into the roof, so replacing them is far from easy. I need to change my rear one its easy remove roof and its all there much quicker than doing front one! I took mine out and lost it lol need a new bolt clio and spring :/ Link to comment Share on other sites More sharing options...
hazza Posted January 9, 2013 Share Posted January 9, 2013 Here's the roof assembly from the parts guide. I purchased part 63296B as well when I bought new bolts from Toyota. Haven't a clue what they do though. I can only imagine they sit in the bolt holes when the roofs off? http://img.photobucket.com/albums/v415/Matt_H/AeroRoofAssembly.jpg i have just orded two rear ones will they come with the small moon shape brackets and the springs? i need them lol i would of thought so? ... Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted May 11, 2014 Share Posted May 11, 2014 Does anyone know the actual thread size of these bolts as i need a tap to clean out the thread on the nut inside the aerotop itself Link to comment Share on other sites More sharing options...
coza Posted August 16, 2019 Share Posted August 16, 2019 Might sound really dumb how do you remove the passenger pillar and handle ... don’t want to snap anything Link to comment Share on other sites More sharing options...
MrGRT Posted August 16, 2019 Share Posted August 16, 2019 I did this recently. Found a post online talking about removing the handle. You need to pull the handle upwards and use a flat screwdriver simultaneously lifting a small tab from underneath the handle. The handle will come out from the top and then you can pull it down. After you remove the screws that hold the metal clips of the handle l, remove metal clips and remove plastic pillar. Link to comment Share on other sites More sharing options...
coza Posted August 16, 2019 Share Posted August 16, 2019 I still can’t see where it clips off Link to comment Share on other sites More sharing options...
MrGRT Posted August 16, 2019 Share Posted August 16, 2019 The plastic cover lift it just a touch carefully only to uncover the top part of the handle, then use a small flat bladed screwdriver and slide it under the grab handle, from the botton into the clip. Flatten the handle, pushing it towards the pillar then pull it towards the headliner while maintaining it flat against the pillar and using the screwdriver to help release it from the clip. Link to comment Share on other sites More sharing options...
coza Posted August 17, 2019 Share Posted August 17, 2019 All done , I never had to remove the handle in the end just lift the pillar enough for the lining to come out post helped a lot though ! Link to comment Share on other sites More sharing options...
