Clinton Posted August 17, 2009 Share Posted August 17, 2009 Hi, Im looking to get a Boost gauge and was just wondering whats better/safer, an electronic or mechanical boost gauge...?? Whats the difference...pros and cons... Thanks in advance Clinton Quote Link to comment Share on other sites More sharing options...
johnny g Posted August 17, 2009 Share Posted August 17, 2009 Electronic is just a wire trailing through from the sender to the gauge. More expensive, but easier to install. Mechanical is a tube that's T'd in your boost line from the turbo and trailed back to the gauge. Cheaper, harder to install as you can get kinks in the line. As for accuracy - it depends on who makes them I suppose... Quote Link to comment Share on other sites More sharing options...
paul mac Posted August 17, 2009 Share Posted August 17, 2009 Electronic is just a wire trailing through from the sender to the gauge. More expensive, but easier to install. Mechanical is a tube that's T'd in your boost line from the turbo and trailed back to the gauge. Cheaper, harder to install as you can get kinks in the line. As for accuracy - it depends on who makes them I suppose... yeah that, electronic have built in circuitry to damp effectively and are in my experience much smoother and readable to use Quote Link to comment Share on other sites More sharing options...
Clinton Posted August 18, 2009 Author Share Posted August 18, 2009 Ok thanks for your replies gents...looks like an electronic boost gauge it is then! Cheers Clinton Quote Link to comment Share on other sites More sharing options...
deathmonkey Posted August 18, 2009 Share Posted August 18, 2009 I have a mechanical Glowshift boost gauge and it's awesome. Responds like lightning and absolute piece of p*** to install. Honestly, if you would rather not spend the money on electrical, mechanical is a simple option also. Not difficult at all. And you won't get kinks in the line if you fit it properly?! Quote Link to comment Share on other sites More sharing options...
