what kind of injectors!?
Guest JDMDOM
Guest JDMDOM
I'm looking to upgrade my fule delivery system to a double pump, fuel rail, regulator and injectors looking to get 650-750 injectors. the question is what is low impedance and high impedance? and what is the diference? wich one is better for a 650whp
either will do dude you just need to change the resistor pack accordingly, if you have a J spec and got hold of a set of low impedence injectors for a UK/US then it would be worth getting a resistor pack from Heckler, if your buying new you may as well get the correct impedence.
there are two types of injector we are talking about here, peak and hold (low impedance) and saturated (high impedance), both have advantages and disadvantages the principle difference being the way they are switched. At the size of injector and the power level you want i would go for peak and hold every time, they react quicker, you will be able to run them direct from your aftermarket ecu (no resistor pack), and saturated injectors dont usually cater for these larger sizes (for a good reason) that you will need
Guest JDMDOM
So hight impandance will be good for about 650whp with out a resistor pack, i have a HKS Fcon V for the ignition/timing and fuel will that be enough along with the fule rail, doulbe or triple pump and regulator? sorry i'm fairly new to the supra scene
I take it you mean an F con pro dude, you will not need more than 2 pumps for 650 hp but you will need 1 larger line or another to run alongside your stock line, I used a -6 and 2 stock filters, remove the fuel pulsation dampner as well, we do a removal kit for this.
Guest JDMDOM
Actually is a Fcon V from jp is not the pro, i been looking online to get specs and i can't find it anywere!! if you know anything about the Fcon V please let me know, i don't if is tuneable, since online the only thing i found was the pics. but what type of removal kit eare you talking about?
