a98pmalcolm Posted August 16, 2009 Share Posted August 16, 2009 Hay guys wierd problem again.... My supra wont go over 1 Bar of boost! I have a HKS fuel cut and a blitz i-colour boost controller... As soon as it gets to 1Bar it just stays around there and holds back. Do you think it will be a controller adjustment or a fault with the fuel cut...or sumin different? Thanks Paul Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted August 16, 2009 Share Posted August 16, 2009 whats your blitz boost controller set to ?? you dont want to be boosting more than 1.2 tbh.. but if your boosting to 1k you might have a small leak if it was boosting higher previously.. Quote Link to comment Share on other sites More sharing options...
SteveR Posted August 16, 2009 Share Posted August 16, 2009 Has it ever boosted >1 bar? Could be a partial boost leak. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted August 16, 2009 Author Share Posted August 16, 2009 yer its been over 1 Bar before... Just randomly started doin it Quote Link to comment Share on other sites More sharing options...
SteveR Posted August 16, 2009 Share Posted August 16, 2009 And did you change any settings? If not, sounds like a leak. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted August 16, 2009 Author Share Posted August 16, 2009 boost leak? god knows were that could be coming from...any common places? Quote Link to comment Share on other sites More sharing options...
SteveR Posted August 16, 2009 Share Posted August 16, 2009 boost leak? god knows were that could be coming from...any common places? Old rubber pipes, connections between hard & soft pipes. Look very carefully, if there is one, it's often very easy to miss. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted August 16, 2009 Author Share Posted August 16, 2009 ok thanks...if i dont get any luck i will have to contact Paul at whifbitz and get him to look at the settings aswell just in case i adjusted sumin by mistake.... Thanks PAul Quote Link to comment Share on other sites More sharing options...
hoff Posted August 16, 2009 Share Posted August 16, 2009 Does sound like a leak. I had a very small one and I was boosting to 0.8 bar. I found the leak, swapped the hose and hey presto, 1 bar. I do have another to locate as I cant get over 1 bar now. Being BPU I would like to see 1.2 on occation. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted August 16, 2009 Author Share Posted August 16, 2009 (edited) i cant find any hose that would course a leak anywere looks like i will have to book it in with Whifbitz as they did the controller! I was always over 1 Bar of boost after the controller was fitted. Edited August 16, 2009 by a98pmalcolm (see edit history) Quote Link to comment Share on other sites More sharing options...
