jacko Posted August 14, 2009 Share Posted August 14, 2009 Pretty easy question here! Is the engine light supposed to come on when the ignition is turned on, when the rest of the lights come on? Quote Link to comment Share on other sites More sharing options...
kaahari Posted August 14, 2009 Share Posted August 14, 2009 yes! Quote Link to comment Share on other sites More sharing options...
jacko Posted August 14, 2009 Author Share Posted August 14, 2009 Thank you, mine doesnt......... Could explain why i had an issue when i tried to see if there were any fault codes stored- i shall investigate tomorrow! Maybe i forgot to plug something back in when i had the dials out ages ago Quote Link to comment Share on other sites More sharing options...
kaahari Posted August 15, 2009 Share Posted August 15, 2009 Seems to be quite common in supras that this righthand connector needs resoldereing... atleast my two jdm supras did But.. if rest of the lights work, maby you got just a broken bulb! Quote Link to comment Share on other sites More sharing options...
sullyd Posted August 15, 2009 Share Posted August 15, 2009 same problem here i uaslly tap it and it comes on gonna investigate it monday when my car comes back Quote Link to comment Share on other sites More sharing options...
jacko Posted August 15, 2009 Author Share Posted August 15, 2009 Seems to be quite common in supras that this righthand connector needs resoldereing... atleast my two jdm supras did But.. if rest of the lights work, maby you got just a broken bulb! Which would you class as rest of the lights? On the dial cluster itself i just get the slip control lights and then the lights under the odo - is that right? Quote Link to comment Share on other sites More sharing options...
jacko Posted August 15, 2009 Author Share Posted August 15, 2009 Just taken the top bit of the dash off and wiggled the connector and the lights come on, so as you said, just needs a bit of soldering - Is the big ! light on the rev dial supposed to light up when the ignition is on? Quote Link to comment Share on other sites More sharing options...
