A bit confused with starting issue
Dazzi
I came to start my car and nothing then tried again and nothing and on about the 5th attempt it fire up but spluttered. When it happened again one of my mates said just tap on it so I did. After doing this it started fine but I realised we tapped on the alternator (left side of engine).... so what is actually buggered the starter or the alt? I have had no loss of power ever from the battery as I can play music fairly loud for about 30mins +... If it is the starter motor that shot why does tapping the alt work? lol
You need to be more specific, when you tried to start the car did it turn over? If not, did the dash lights go dim? did you hear a loud click when you turned the key?
Sounds like Starter contacts to me. Oh and tapping the Alternator wont do anything.
It didn't turn over no. After about the 5th attempt it finally turned over but struggled to. The dash light were going dim yes as I was trying to start it but as I said previously it can't be the battery. Yea when I turned the key it went 'CLICK' but didn't turn over then 'CLICK' again. It does this until it fires up.
Hitting the starter (or I guess near it in the early stages) says it's on the way out, but it can be rebuilt. I know Chris Wilson can refurb them for a lot less than a new one, other people may be able to do it as well. Have a search for starter solenoids and see what you get :)
-Ian
