Idling a Revving up issues after single install
guye_d
Guys,
Posted a thread before; having issues after my single install.
My car is a 6spd VVTI TT .... now tih a T61 installed
Got the single install completed, had a few startup issues, but finally got it to work with the emanage compensating for the 650cc injectors installed. Was having issues revving beyond 2k, so took off the emanage and reverted to the 440cc to determine if all was fine with the car. and therefore I would be able to look towards the emanage for my issues.
Problem is, with the 440cc in the car is stuggling to idle; its apparent that the car is trying to learn, but dies after 30 seconds or so. also between idle and 3 k rpm, the car finds it difficult to rev, however, from 3-4k it revs just fine. This is all with the 440cc injectors installed.
First Question is, should the car idle and rev fine with the single installed and 440cc injectors in?
I'm not sure if the vvti throttle sensor is the same, but the early one has a switch for when the throttle is closed. That's adjusted by rotating the TPS and checking with a multimeter that it's switching when the throttle is almost closed. So yes that could affect idle, if the switch isn't closing the idle rpm would probably be low.
Don't know about the rest, I don't think the revving problem could be explained by the TPS :search:
Thanks Scott
Hermit, will check and post findings here
Dude, Keep on hearing that the emanage won't work; bought it cheap off a mate so decided to give it a shot
Miguel, not taken anyway mate, its the smallest things we sometimes forget; but yeah, the MAF is on.
Dudley
We also pulled the engine to do lil things like change seals and gaskets, oil pump etc. Was told that it may be the TPS that needs re-calibrating. Any thoughts on this?
Only if you have disturbed the TPS. If they remain in the same position as they did before you pulled the lump, then they should be fine.
There is a procedure for the vvti TPS in the WS Manual floating about somewhere.
Not using the car at the mo.It runs ok though under 4000 rpm.It hit's the factory boost cut soon after that.So i've decided not to use it untill it's all sorted, as i would be gutted if i got carried away with the throttle and ended up with cracked pistons or worse.
There's a fuel system upgrade on the way shortly.Just fitted a HKS DLI and bought a AEM EMS + 3.5 bar map sensor to match.
Can't wait to get this lot fitted and mapped :)
Sooo a bar of boost on stock injectors and ECU, but a T67 sized turbo, *and* run in the region that the stock ECU runs at 13:1 afrs? You're a 'braver' man than I... not using it is a good idea, hopefully it's still OK.
