valve stem seal difference. Quick info please!
mattysupra
help please, waiting to refiet valves but cant work out which seal is exhaust or inlet.
The new ones are different. One has a brown rubber that lips on top of the metal valve seal.
The other is black and more metal on show.
Which is which?
The old ones i took out look the same as each other but the exhaust side has a number on but the inlet is blank .
Thanks.
thats what i was thinking also.
I have no numbers. Im building it for my cousin who brought the car off me a while back. He has brought a head kit direct from japan and they have put the new valve seals all in the same bag with no reference or numbers to tell them apart.
However i need to get them the correct away around!
what is the difference between the two sides? (exhaust/inlet) as i have measured thickness of valve shafts and they seem the same
I think im going to have to order the correct toyota ones to be safe
I think that would be the wise thing to do. It's not the sort of job you'd want to do twice, is it!
fyi: When I priced this job up a while ago I found it was as cheap to buy a complete head service kit (Head gasket etc) as to buy the stem seals alone. (that was through Steve Manley)
