Carl Posted August 11, 2009 Share Posted August 11, 2009 I have fitted my Blitz power meter & boost controller next to each other. Both are wired up and come on with ignition. As yet i have not plumbed in the boost control unit under the bonnet so I only have the visual of the units switching on. My question is, should the power meter still work independantly of the boost control (SBC-Id) or will it not work untill I plumb in the boost control. I just thought that given the power meter is wired off the pink speed signal wire that it would be taking its own reading and showing some display movement. I get nothing other than static figures. Can someone clarify if this is the case or whether it means my wiring is wrong somewhere? Cheers Carl Quote Link to comment Share on other sites More sharing options...
Carl Posted August 11, 2009 Author Share Posted August 11, 2009 Anyone? Quote Link to comment Share on other sites More sharing options...
