gt4tosupra Posted August 10, 2009 Share Posted August 10, 2009 Has anyone read Japanese Performance mag Sep09 issue? page 28 shows a small article about an NA that has been turbo'd without swapping the engine. If this is done, how much would it cost roughly, and would engine internals survive? Link to comment Share on other sites More sharing options...
Guest Budz86 Posted August 10, 2009 Share Posted August 10, 2009 This is possible to do, search for NA/T conversions. The 2JZ-GE (non-turbo) is pretty much the same as the 2JZ-GTE (twin turbo) but the latter has more oilways for better lubrication and a slightly higher compression ratio. With the NA/T conversion you are looking at paying around £3-4k still but are limited to around 550 bhp I believe *wait's to be corrected!*. The reason the TT conversions are so popular is the cost around the same money but give much more options with regards to tuning at a later date. HTH Link to comment Share on other sites More sharing options...
Kirk Posted August 10, 2009 Share Posted August 10, 2009 (edited) turbo'ing an NA costs the same as single turbo'ing a TT. Only drawbacks are headgasket needs changing to lower compression in order to UP the boost and power, as the most you can boost safely is around 8psi on the stock HG and the w58 wont last long with anything over 400bhp running through it. Also engine internals are just as strong as the TTs. Edited August 10, 2009 by Kirk (see edit history) Link to comment Share on other sites More sharing options...
dcarrter21 Posted August 10, 2009 Share Posted August 10, 2009 i brought and fitted a tt engine with new clutch, decat, fuel pump, rocker cover gaskets front oil seal and all the sump gaskets for under £2500 + a few beers! Link to comment Share on other sites More sharing options...
Kearney Posted August 10, 2009 Share Posted August 10, 2009 i brought and fitted a tt engine with new clutch, decat, fuel pump, rocker cover gaskets front oil seal and all the sump gaskets for under £2500 + a few beers! Bargain Link to comment Share on other sites More sharing options...
dcarrter21 Posted August 10, 2009 Share Posted August 10, 2009 oh plus it had only done 43k :-) Link to comment Share on other sites More sharing options...
gt4tosupra Posted August 10, 2009 Author Share Posted August 10, 2009 turbo'ing an NA costs the same as single turbo'ing a TT. Only drawbacks are headgasket needs changing to lower compression in order to UP the boost and power, as the most you can boost safely is around 8psi on the stock HG and the w58 wont last long with anything over 400bhp running through it. Also engine internals are just as strong as the TTs. Nice! So how much does it cost, approx, to single turbo mine? Including new HG, turbo, and i'm guessing bigger fuel pump. I'm only looking for about 300bhp, nothing too mental, yet. . . . Link to comment Share on other sites More sharing options...
Kirk Posted August 10, 2009 Share Posted August 10, 2009 300s is about what you will get on a stock HG. Bigger pump recommended, some drop in injectors also recommended as you will max out the stock 1s. There are kits at the minute that range from bout 2-4k roughly.. there is someone actualy selling an NA turbo manifold in the for sale section if you wanted to piece it together yourself. Best option is asking dusty (mvpmotorsports) or joe (powerhouseracing) Link to comment Share on other sites More sharing options...
Thorin Posted August 11, 2009 Share Posted August 11, 2009 Nice! So how much does it cost, approx, to single turbo mine? Including new HG, turbo, and i'm guessing bigger fuel pump. I'm only looking for about 300bhp, nothing too mental, yet. . . . It would probably cost less to just fit a TT engine. Link to comment Share on other sites More sharing options...
supspower Posted August 11, 2009 Share Posted August 11, 2009 To be fair you can NA-T for under less than 2k sourcing 2nd had parts. When i was looing into it i sourced brand new parts including mapping and everything needed to hit around 340bhp for £2281 all in incs installing the kit too. Bare in mind though thats "if" and i mean a big "if" you dont run into any problems. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 11, 2009 Share Posted August 11, 2009 This is possible to do, search for NA/T conversions. The 2JZ-GE (non-turbo) is pretty much the same as the 2JZ-GTE (twin turbo) but the latter has more oilways for better lubrication and a slightly higher compression ratio. It has a lot LOWER compression ratio, different pistons, different cams, different induction, very different in fact. The cheapest and most reliable option is to fit a TT engine and ecu complete, IF, for some bizarre reason, the question poser can't bring himself to sell the N/A and just buy a TT. That is BY FAR the best course to take, but staggeringly, to me, one which no one seems to want to follow. Link to comment Share on other sites More sharing options...
gt4tosupra Posted August 11, 2009 Author Share Posted August 11, 2009 It has a lot LOWER compression ratio, different pistons, different cams, different induction, very different in fact. The cheapest and most reliable option is to fit a TT engine and ecu complete, IF, for some bizarre reason, the question poser can't bring himself to sell the N/A and just buy a TT. That is BY FAR the best course to take, but staggeringly, to me, one which no one seems to want to follow. Cheers! Good advice mate! The reason i personally would rather upgrade or swap my engine instead of the whole car, is that i paid top whack for an excellent cond. car, so want to hang on to it! A TT in as good nick as my NA would cost around 8k, i'm guessing![sHOCK][/sHOCK] So the engine internals are different then? Link to comment Share on other sites More sharing options...
bromy Posted August 11, 2009 Share Posted August 11, 2009 Cheers! Good advice mate! The reason i personally would rather upgrade or swap my engine instead of the whole car, is that i paid top whack for an excellent cond. car, so want to hang on to it![sHOCK][/sHOCK] So the engine internals are different then? This is the reason I had mine done. If you really have your heart set on it then do it but for gods sake buy a decent kit and get a good garage to fit and map it. If I had my time again it would be a TT transplant but only for the money side of it... you cant beat the sound of a single. Link to comment Share on other sites More sharing options...
ray007 Posted August 11, 2009 Share Posted August 11, 2009 i have a single turbo kit for the na if you really waana go ahead with it. Garret T04R turbo HKs wastegate uprated injectors boostlogic na-t turbo manifold xs power down pipe and mid pipe Aeromotive Fuel pressure regulator Boost controller Greddy emanage blue with harness, boost map sensor and software Its near enough all you need, just probably need oil feed and return line and a intercooler if going over 7-8 psi for which you will need to do the head gasket but in turn would probably get more lag. theres a guy who has done the na-t on with the stock gasket and claims to be keeping up with a 400bhp skyline. i was going to do it but ended up buying a cheap na-TT, a bit lucky i guess. if you have a good mechanic, then go for it!! and good luck mate Link to comment Share on other sites More sharing options...
mr veilside Posted August 11, 2009 Share Posted August 11, 2009 Ray007 wrote: i have a single turbo kit for the na if you really waana go ahead with it. Garret T04R turbo HKs wastegate uprated injectors boostlogic na-t turbo manifold xs power down pipe and mid pipe Aeromotive Fuel pressure regulator Boost controller Greddy emanage blue with harness, boost map sensor and software How much for the complete kit? Link to comment Share on other sites More sharing options...
Homer Posted August 11, 2009 Share Posted August 11, 2009 This is the reason I had mine done. If you really have your heart set on it then do it but for gods sake buy a decent kit and get a good garage to fit and map it. If I had my time again it would be a TT transplant but only for the money side of it... you cant beat the sound of a single. If you have a great NA and do not want to lose it, then the TT swap is by far the most cost effective option in terms of reliability, power and cost. It'll also deliver the same level as power as and NA-T, but at a far lower cost. The problem comes when NA-T conversions want more power. It needs so much work deliver reasonably large power that it becomes incredibly expensive (since most of the NA parts will be replaced with TT ones). If you're going for more than 400bhp and want to keep the NA shell, then by a very long way the most cost effective way is to fit a TT lump, box, diff and single it. It will cost a lot of money, but in the long run will deliver considerably more power and longevity than the NA-T route which is fundamentally flawed and restricted. Believe me, I spent weeks on end pricing up all the options and the only one worth considering it the TT swap (I have an NA as well)) That said, it's more cost effective to just sell up and buy a genuine TT in the first place. It peanuts to take it to 400bhp. Link to comment Share on other sites More sharing options...
bromy Posted August 12, 2009 Share Posted August 12, 2009 If you have a great NA and do not want to lose it, then the TT swap is by far the most cost effective option in terms of reliability, power and cost. It'll also deliver the same level as power as and NA-T, but at a far lower cost. The problem comes when NA-T conversions want more power. It needs so much work deliver reasonably large power that it becomes incredibly expensive (since most of the NA parts will be replaced with TT ones). If you're going for more than 400bhp and want to keep the NA shell, then by a very long way the most cost effective way is to fit a TT lump, box, diff and single it. It will cost a lot of money, but in the long run will deliver considerably more power and longevity than the NA-T route which is fundamentally flawed and restricted. Believe me, I spent weeks on end pricing up all the options and the only one worth considering it the TT swap (I have an NA as well)) That said, it's more cost effective to just sell up and buy a genuine TT in the first place. It peanuts to take it to 400bhp. Agreed, My conversion all in probably somewhere in the region of 6-7k Link to comment Share on other sites More sharing options...
imi Posted August 12, 2009 Share Posted August 12, 2009 The 2JZ-GE (non-turbo) is pretty much the same as the 2JZ-GTE (twin turbo) but the latter has more oilways for better lubrication and a slightly higher compression ratio. Believe the latter has a LOWER compression ratio while the former has a higher one Link to comment Share on other sites More sharing options...
imi Posted August 12, 2009 Share Posted August 12, 2009 That said, it's more cost effective to just sell up and buy a genuine TT in the first place. It peanuts to take it to 400bhp. amazing how spending £1.5K to go BPU looks like peanuts when comparing it to the cost of going single Link to comment Share on other sites More sharing options...
ray007 Posted August 12, 2009 Share Posted August 12, 2009 How much for the complete kit? if your intrested i will sell the; Garret T04R turbo HKs wastegate uprated injectors boostlogic na-t turbo manifold xs power down pipe and mid pipe all the above for £500 only to clear Aeromotive Fuel pressure regulator - £95 Blitz dsbc Boost controller - £150 Greddy emanage blue with harness, boost map sensor and software £300 only if bought with package otherwise £325+del T4 turbo blanket £100, brand new from MVP motor sports worht £150ish if you take the lot ill let you have it for £1000 Ray Link to comment Share on other sites More sharing options...
gt4tosupra Posted August 12, 2009 Author Share Posted August 12, 2009 This does all sound good everyone, and my car is SZr so has 6 speed box already!! Just gathering info for now tho, then gotta save some money then take action! Link to comment Share on other sites More sharing options...
Konrad Posted August 12, 2009 Share Posted August 12, 2009 if your intrested i will sell the; Garret T04R turbo HKs wastegate uprated injectors boostlogic na-t turbo manifold xs power down pipe and mid pipe all the above for £500 only to clear Aeromotive Fuel pressure regulator - £95 Blitz dsbc Boost controller - £150 Greddy emanage blue with harness, boost map sensor and software £300 only if bought with package otherwise £325+del T4 turbo blanket £100, brand new from MVP motor sports worht £150ish if you take the lot ill let you have it for £1000 Ray Very reasonable price for an equipment you offering It will need intercooler too. Link to comment Share on other sites More sharing options...
ray007 Posted August 12, 2009 Share Posted August 12, 2009 Very reasonable price for an equipment you offering It will need intercooler too. oh yes - defo need an intercooler if going over 6psi. for which you will need to change the head gasket to lower compresion which i probably wouldnt advise, ive heard it will give you turbo laaaag!! Link to comment Share on other sites More sharing options...
gt4tosupra Posted August 13, 2009 Author Share Posted August 13, 2009 so is there a different (easier)way to get to, lets say, 260 ish bhp? car has already been decatted and has blitz nur spec! Link to comment Share on other sites More sharing options...
stevie_b Posted August 13, 2009 Share Posted August 13, 2009 (edited) so is there a different (easier)way to get to, lets say, 260 ish bhp? car has already been decatted and has blitz nur spec! I suppose you could investigate NOS, but personally I wouldn't do that, mainly due to ongoing (refill) costs of using NOS, insurance issues, and ability to lunch your engine if not done correctly. (I'm no expert on this though). If your target is 260bhp, I would just replace your NA lump with a TT one any day of the week, and leave the TT lump stock. No need to even decat it. If you buy an engine with a known history from a reputable trader on here, it may help to cut out some of the uncertainty in dropping a new lump in. If all you want is to drive a 260bhp-ish car, I wouldn't underestimate the advantages of using a stock engine running with stock parts. It's all very well using an eclectic mix of aftermarket parts and engine management systems if you like to tinker with cars, and are prepared for drawn-out troubleshooting exercises if things go wrong. All IMO. Edited August 13, 2009 by stevie_b (see edit history) Link to comment Share on other sites More sharing options...
