ClaireRZ-S Posted August 10, 2009 Share Posted August 10, 2009 Right thinking of getting the car mapped to irish fuel, i'm afraid to put the 1st decat in without getting this done as my car is mapped to 100ron and there is only 97ron around here. What aftermarket ecu do i need for this? Quote Link to comment Share on other sites More sharing options...
heckler Posted August 10, 2009 Share Posted August 10, 2009 Right thinking of getting the car mapped to irish fuel, i'm afraid to put the 1st decat in without getting this done as my car is mapped to 100ron and there is only 97ron around here. What aftermarket ecu do i need for this? Same fuel as UK Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 10, 2009 Share Posted August 10, 2009 V-Power and Tescos Super in the UK is 99 ron Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted August 10, 2009 Share Posted August 10, 2009 How do you know the car is mapped to 100RON? Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 10, 2009 Share Posted August 10, 2009 How do you know the car is mapped to 100RON? Sourced directly from Japan? Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted August 11, 2009 Author Share Posted August 11, 2009 yep got her directly from japan we have E5 here which is 99RON but its very hard to get and theres no petrol station close to me that does it. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted August 11, 2009 Share Posted August 11, 2009 I've read that the stock ECU retards the timing quite a bit when it runs on our lower octane crud. If you're concerned, reset the ECU so it's forced to run with new values. Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted August 11, 2009 Author Share Posted August 11, 2009 Ok so resetting the ecu will fix this??? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 11, 2009 Share Posted August 11, 2009 The std ECU will auto retard when it detects knock, but it will keep trying to re advance, as it doesn't know what petrol is in the tank as some people seem to think. I have not known running 95 or 98 to be a problem. Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted August 11, 2009 Author Share Posted August 11, 2009 ok so if my engine blows up i will blame you all Quote Link to comment Share on other sites More sharing options...
Guigsy Posted August 11, 2009 Share Posted August 11, 2009 im sure your safe. i ran my na on 97 about 50% of the time and it was fine. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted August 11, 2009 Share Posted August 11, 2009 The Stock ECU contains multiple maps, if you disconnect the battery for a few mins and reconnect, the ECU is reset and it will learn what is the best map to use Marty in Supra Specialists Ireland will confirm, no need to remap Supra's for Ireland I have ran a few tanks of the E5 99Ron and found the Texaco Techron better Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 11, 2009 Share Posted August 11, 2009 The Stock ECU contains multiple maps, if you disconnect the battery for a few mins and reconnect, the ECU is reset and it will learn what is the best map to use Marty in Supra Specialists Ireland will confirm, no need to remap Supra's for Ireland I have ran a few tanks of the E5 99Ron and found the Texaco Techron better Its not a case of multiple maps, its not a self learning ECU as such, just a number of default sub map adjustments should certain parameters be met. like knock being detected if low octane fuel being used, the same goes should the lambda or MAO go faulty etc. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted August 11, 2009 Share Posted August 11, 2009 Its not a case of multiple maps, its not a self learning ECU as such, just a number of default sub map adjustments should certain parameters be met. like knock being detected if low octane fuel being used, the same goes should the lambda or MAO go faulty etc. I taught thats what a car mapper does, is adjust certain key parameters to best suit the conditions and resources the engine has available Quote Link to comment Share on other sites More sharing options...
Jellybean Posted August 11, 2009 Share Posted August 11, 2009 (edited) Marty from SSI (Supra Specialest Ireland) did mention this before for a cork car running on what u guys have down there He is a member on here Stock ECU has some very clever Knock detection and timing retard maps built in, which means you'll be fine on stock boost levels http://www.supras-ireland.net/phpBB3/viewtopic.php?f=22&t=729&p=4024&hilit=ecu#p4024 -------------------------------------------------------------------------------- Some info from Supra Specialists Ireland on E85 Its actually rated at 98.2 Ron i believe. And i'm also going to give a little tip to anyone going to switch to it Full time. E5 is a blended Fuel which is 95% petrol and 5% eth. If uou know how combustion works on a petrol engine you will know that the Stioch value of Petrol is 14.7:1, and so your ECU o2 feedback is programmed for this. Adding Eth will throw this of sligtly as Eth has a lower Stioch value. After filling the tank, remove power to the ECU for a few minutes (remove earth lead) and this will clear the Stored o2 feedback values to the ECU). After restarting the car, the ECU will have to relearn its o2 feed back strategy, which may take around 30 miles of driving, but it will be a strategy to work with the new fuel. Will disconecting the Battery alone reset the ECU?? Edited August 11, 2009 by Jellybean (see edit history) Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted August 11, 2009 Author Share Posted August 11, 2009 Ah ok cool thanks i need to know if i can do this for 1.2 Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 11, 2009 Share Posted August 11, 2009 Marty from SSI (Supra Specialest Ireland) did mention this before for a cork car running on what u guys have down there He is a member on here Stock ECU has some very clever Knock detection and timing retard maps built in, which means you'll be fine on stock boost levels Which is exactly what i said, any STD ECU especially turbo cars is capable of this, nothing special, it doesn't have a multitude of maps for all occasions built in, just the defaults that Toyota mappers expect on a normal road car. http://www.supras-ireland.net/phpBB3/viewtopic.php?f=22&t=729&p=4024&hilit=ecu#p4024 -------------------------------------------------------------------------------- Some info from Supra Specialists Ireland on E85 Its actually rated at 98.2 Ron i believe. And i'm also going to give a little tip to anyone going to switch to it Full time. E5 is a blended Fuel which is 95% petrol and 5% eth. If uou know how combustion works on a petrol engine you will know that the Stioch value of Petrol is 14.7:1, and so your ECU o2 feedback is programmed for this. Adding Eth will throw this of sligtly as Eth has a lower Stioch value. After filling the tank, remove power to the ECU for a few minutes (remove earth lead) and this will clear the Stored o2 feedback values to the ECU). After restarting the car, the ECU will have to relearn its o2 feed back strategy, which may take around 30 miles of driving, but it will be a strategy to work with the new fuel. Will disconecting the Battery alone reset the ECU?? I can't see how the above procedure will make any difference as a std O2 sensor can only respond to the combustion process so no matter what additives you add, as soon as you revert to normal petrol it will just run stoic,it just a switch that the ECU responds to, and in any case this has absolutely no effect during positive boost or over 4,000 RPM Quote Link to comment Share on other sites More sharing options...
Jellybean Posted August 11, 2009 Share Posted August 11, 2009 I can't see how the above procedure will make any difference as a std O2 sensor can only respond to the combustion process so no matter what additives you add, as soon as you revert to normal petrol it will just run stoic,it just a switch that the ECU responds to, and in any case this has absolutely no effect during positive boost or over 4,000 RPM E85 is sold from the pump over here as Unleaded Petrol by Maxol @99RON everything else is 95 RON http://www.maxol.ie/maxol-bioethanol-e85.html You would have to ask Marty at SSI, just reiterating what he said I cant comment on it but all I know he is a respected tuner in the Supra Community UK and Ireland Quote Link to comment Share on other sites More sharing options...
simonsupra Posted August 11, 2009 Share Posted August 11, 2009 i have been running mine on 95ron for 3 years no problems put a tank of 99 in by accident couldnt tell the difference Quote Link to comment Share on other sites More sharing options...
bondango Posted August 11, 2009 Share Posted August 11, 2009 (edited) Ricky My post is taken slightly out of contex there E85 i dont think is available on the mainland, or here in N.Ireland, but is availble throughout the R.O.I My Post was made when Irish stations introduced the fuel on the forcourts, unfortunately with not alot of info on it. Although its Ron rating is that of Super unleaded it is not a straight super unleaded fuel, its an unleaded/Ethonal blended fuel, so its burn process is slightly different. My reason for saying to Remove the EFI power is to clear any long term fuel Trims, those trims are data adjustments which are added to ecu fuel maps - based on Short term fuel trim data (dictated by O2 feedback). As we know the ECU will go into relearn mode and carry out its basic relearn procedures such as Idle strategy, another will be clearing any stored fuel trims and starting again..i.e something you must do after replacing an o2 sensor, as the LTFT data is based the old sensors info to the ecu Now using different types of Unleaded fuel i.e super or ordinary unleaded wouldnt require this, but as E85 is neither i thought it would be a good idea to let the ECU re-adjust the above as a precautionary measure Edited August 11, 2009 by bondango (see edit history) Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 11, 2009 Share Posted August 11, 2009 Just to clarify folks: E85 is only for use in flexi-fuel cars or engines that have been mapped to run on it. E5 fuel is the high grade (99 ron) fuel available for use in all unleaded cars. Quote Link to comment Share on other sites More sharing options...
bondango Posted August 11, 2009 Share Posted August 11, 2009 Just to clarify folks: E85 is only for use in flexi-fuel cars or engines that have been mapped to run on it. E5 fuel is the high grade (99 ron) fuel available for use in all unleaded cars. Yes, sorry, i was reffering to E5 in my post above (5% eth. Blended Fuel) which is ROI equiv fuel to the UK's super unleaded fuels. E85 is an 85% eth. blend (108 ron) and although intended for flex equipped cars it can be used in any car with the correct fuel system mods and mapping i.e. the combustion needs around 30% more E85 than it would unleaded petrol, but due to its RON rating, it may become a better alternative to race fuels if the prices and availability get better Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted August 19, 2009 Author Share Posted August 19, 2009 ok so yes or no running 1.2 bpu with irish fuel Quote Link to comment Share on other sites More sharing options...
suprab Posted August 19, 2009 Share Posted August 19, 2009 i ran 1.2 bar both cats out ect for ages with the stock ecu..never any trouble, never used anything special in the fuel just the regular 95, and i had a wideband fitted it looked as if it was running slightly rich Quote Link to comment Share on other sites More sharing options...
