monsween Posted August 10, 2009 Share Posted August 10, 2009 Alright chaps. Anyone handy with Visual basic for excel? I would like to be able to reference cells so that certain information can be put into an email that can then be used to inform the correct person what stock to order. Here is what i've come up with so far: Sub OrderStock() 'Variable declaration Dim oApp As Object, _ oMail As Object, _ WB As Workbook, _ FileName As String 'Turn off screen updating Application.ScreenUpdating = False 'Create the email template Dim strbody As String With ActiveSheet strbody = "Hi," & vbNewLine & vbNewLine & _ "Could you order these items for me" & vbNewLine & vbNewLine & _ "Part Number: " & _ .Range("A34") & vbNewLine & _ "Description: " & _ .Range("B34") & vbNewLine & _ "Quantity: " & _ .Range("N34") & vbNewLine & vbNewLine & vbNewLine & _ "Regards" & vbNewLine & _ "Stores" End With 'Create and show the outlook mail item Set oApp = CreateObject("Outlook.Application") Set oMail = oApp.CreateItem(0) With oMail 'Uncomment the line below to hard code a recipient .To = "[email protected]" 'Uncomment the line below to hard code a subject .Subject = "Order" .Body = strbody .Display End With End Sub The problem being is that i want one marco that can be used for the whole operation. The values i need are from the collumns A,B and N. and rows 10-200+ How do i change it so i can reference one specific set of A's B's and N's?? IE in the example above it references row 34 into the email. I have a button that is linked to the macro then a box next to it to type in the row number that is to be ordered. So if item in row 54 needed to be ordered, type 54 into the box then hit the order button and the correct data would be referenced from A54, B54 and N54. Then subsequently sent out via email. Thanks in advance Kieran Quote Link to comment Share on other sites More sharing options...
MrRalphMan Posted August 10, 2009 Share Posted August 10, 2009 You can use the following to get the text from a CELL. Cells(1, 1).Text So you could use .Range("A&Cells(x, y).Text) & vbNewLine & _ Where x = row number and y = column number. Even better DIM a variable up the top MyRowNumber Set this to the value and then put that into the line above. .Range("A&MyRowNumber) & vbNewLine & _ See if that works.. Quote Link to comment Share on other sites More sharing options...
monsween Posted August 10, 2009 Author Share Posted August 10, 2009 i'll have a go at that when i get to work tomorrow, anyone else with any other ideas incase that doesnt work? Quote Link to comment Share on other sites More sharing options...
