I've got a leak. HEEEELLLPPPP
Bill Prawn
I have a water leak at the back of the wheel behind the belt.
There is a bolt where it it seems to be dripping from.
Water pump?
Or something else?
I have the technical knowledge of a Gnat so please treat me gently.
Yes it did overheat, yes there was a small puddle under the car and no it's not still leaking.
Any advice will be greatly appreciated. :) :thumbs:
Sounds like water pump from your (crap :D) description.
I said be gentle
Any chance of a pic of the bolt it's leaking from?
The flywheel is behind the engine inside the gearbox bell housing.
Piccie here (it's crap as well) :tongue:
It's the bolt in the middle of pic.
Water pump seal and / or bearings are gone. there is a drain hole under the pump to allow water that seeps past the seal to escape, it's from this i would say the water is exiting from. I have pumps in stock. Get it done ASAP as it will get worse. maybe fail altogether. Not worth risking overheating or a blown head gasket or worse!! Top the water in the rad and overflow bottle up EVERY time you use the car, meanwhile.
