Replacing central heating radiator
robin
I know this isnt a DIY or plumbing forum but the members on here seem to know how to do just about everything :)
I have a bad radiator in that the tread is damaged and its leaking and I would like to replace it.
It is a double radiator and measuring from end to end its 970mm which is a bit of an odd size and makes me think I might be measuring from the wrong place.
Does anyone know where I can get a 970x600mm radiator? I can only find 900 or 1000mm; nothing in between. This radiator is at least 23 years old, possibly more so it might be 38" or something else imperial.
Anyone have any ideas as I don’t really want to be using 7cm of extension pipes or having to cut and lengthen the existing ones pipes to fit a 1000mm one in unless of course that is the size and im measuring it wrong.
Exactly what do you mean, is it the bit that screws into the radiator as I've shown in the pic? :)
I'll be very surprised if the radiator needs replacing?
It just depends Mercx because the thread on there is tapered, sometimes if it has been tightened to much it can split the female thread on the radiator, nut if the leak is from there it is definately worth taking the tail out and replacing with a new one ensuring you use a nice amount on PTFE to seal it
It is leaking arround the bleed valve. I have tried to take the whole valve out but the metal ended up deforming before it would turn as it is so rusted up. It might be possible to drill and retap it but that seemed like more work.
I have found a Myson Premier HE 530 x 946mm Double Convector Radiator which is very close to the right length.
Where exactly should I be measuring from, is it valve to valve or just the actual radiator body?
The myson I have found is only 10mm out so should fit but its 140 quid and a 900mm radiator can be had for less then half the price and I can live with a couple of extention tubes.
My next question would then be do I need new valves? I hope not as I dont want to have to drain the whole system.
Thanks for the help so far guys.
u just need new tails that (parts from the valve to the radiator)
you should beable to get them from any decent plumbing supplier
just make sure you get the right sized extensiona nd the right size nut on it (looks like a half inch nut from the pic)
For the sake of an extra tenner yo should just change the valves as well.
You are going to all the hastle of changing a rad, doing the valves will take 5 mins.
You also don't need to drain the whole system (if you are quick with your hands) Being, what looks like a 15mm fitting it should be fairly easy to loosen up, thumb and retighten the new valve in place, without flooding the place :)
yeah thats the type of thing you need and it will be a half inch nut that will fit
If you can get the old tails out of the old radiator you will beable to use them again, just remove all PTFE tape and any sealant and put some new PTFE tape on and that will seal it
but if you are changing the valve i is always best to change the nut and olive that is on the existing pipe as you dont no if who has fitted it before. and if its a brass olive and its been overtightened before hand a good seal wont be possible as it will have distorted the shape of the pipe
I intend to leave the valves for now as they both work fine and I dont see any value in having posh thermostatic valves in only one room. They also look pretty clean and the thread looks good too. The radiator on the other hand has rusted seams and generally looks pretty rough. Odd really as all the other radiators in the place look fine and the water that came out was pretty clean too.
The prices for the radiators at Toolstation are the cheapest where I live, we've bought a few. :)
If you login you can see if they've got any stock at your local branch.
Free next day delivery too if you would rather have it delivered, only a minimum spend of £10 for the free next day delivery which is very good indeed.
http://www.toolstation.com/shop/Heating/d230
