Tee from China Posted August 8, 2009 Share Posted August 8, 2009 Whilst on the SF found this link where a guy has used an external wastegate instead of the small internal one on standard twins - good or bad thing? link:- http://www.utahracing.com/supras/matt/matt94/wastegate/index.htm Quote Link to comment Share on other sites More sharing options...
Jamesy Posted August 8, 2009 Share Posted August 8, 2009 If it means i can whack a screamer pipe on then good!! Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 8, 2009 Share Posted August 8, 2009 Will doing this make restrictor rings redundant? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 8, 2009 Share Posted August 8, 2009 Will doing this make restrictor rings redundant? Yes! as long as the waste gate/pipework is of adequate size, lot of buggering about though, for only a small gain. Quote Link to comment Share on other sites More sharing options...
Jamesy W Posted August 8, 2009 Share Posted August 8, 2009 (edited) If it means i can whack a screamer pipe on then good!! Can anyone hazard a cost as to how much something like this would run you? I'm gonna be having my J specs replaced shortly, so may give it a whirl. Edited August 8, 2009 by Jamesy W (see edit history) Quote Link to comment Share on other sites More sharing options...
Geo Posted August 8, 2009 Share Posted August 8, 2009 Can anyone hazard a cost as to how much something like this would run you? I'm gonna be having my J specs replaced shortly, so may give it a whirl. id save your cash for replacing you twins, 650cc injectors and a good ECU then mapped. Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted August 8, 2009 Share Posted August 8, 2009 its a very worthwhile mod for a j-spec car in my opinion Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted March 2, 2011 Share Posted March 2, 2011 Is there any more info on this? I dont really understand external wastgate setups very good, i always thought that you had to have after market turbo's? Is there a kit to go with the atandard twins? Love the chattering Cheers D Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted March 2, 2011 Share Posted March 2, 2011 The chattering isn't the wastegate. It's compressor stall caused by ineffective release of back pressure when the throttle is closed. Quote Link to comment Share on other sites More sharing options...
JustGav Posted March 2, 2011 Share Posted March 2, 2011 its a very worthwhile mod for a j-spec car in my opinion Not sure, I'd agree... The amount of work to do it is a lot... remember the stock manifolds are cast and are fairly complex, so you would need to somehow drill it, get it to the right diameter for the waste, then fit one and then get the screamer pipe either ducted out of the car or into the exhaust.. Something just tells me that toyota got it right.... Quote Link to comment Share on other sites More sharing options...
Nic Posted March 2, 2011 Share Posted March 2, 2011 Is there any more info on this? I dont really understand external wastgate setups very good, i always thought that you had to have after market turbo's? PA5T5PnWE-k Is there a kit to go with the atandard twins? Love the chattering There are no external wastegate kits available for the stock turbos, it would require modification of the stock manifold/turbos and some custom fabrication. If someone had the skills to do it themselves then it may be a worthwhile mod on a J-spec setup. If you were paying someone to do the work it would be very expensive for negligible gains. As Gaz explained the 'chattering' is not caused by the wastegate. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted March 2, 2011 Share Posted March 2, 2011 As Gaz explained the 'chattering' is not caused by the wastegate. Removing the stock BOV and fitting an aftermarket induction kit should achieve that though. Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted March 2, 2011 Share Posted March 2, 2011 Cheers for the video and replies As i say im pretty new to a lot of this having had N/A cars usually so like to learn new stuff. D Quote Link to comment Share on other sites More sharing options...
Nic Posted March 2, 2011 Share Posted March 2, 2011 As i say im pretty new to a lot of this having had N/A cars usually so like to learn new stuff. Have a read through the Turbo Tech Tutorials HERE. Quote Link to comment Share on other sites More sharing options...
