Shed Clearout (Interior bits + Wheels)
AlexM
Would you do a special price on all the plastic trim bits?
Let me know what you have in mind.
The right rear light has a load of stress marks on the outer plastic (£5), left one is ok apart from a couple of very minor scratches on the outside (just needs a clean!), so that one is £10.
How big are the wheels?
Fronts - 18x8.5, Tyres 225/40 (Tyres have a couple of mm, outside edge of offside wheel is worn)
Rears - 18x9.5, Tyres 255/35 (Tyres are on the wear markers)
They require spigot rings, I damaged the ones I have taking them off. Include full set of wheel nuts (4x locking). I don't know the offset, and have only used them over the smaller 'jspec' brakes.
Guest superdave
Hello Alex.
Do you still have the kerb side polystyrene bit that goes in the boot? Also do you have any of the internal panel screw hole plugs?:search:
