pjavon Posted August 5, 2009 Share Posted August 5, 2009 I've just put a camera in my car and connected it up to the stereo, everything worked fine but now I've put the dash back in the heater and clock don't work! I've checked the fuses in the drivers foot well and all is o.k. The lights come on the heaters when the side lights are on but nothing else. I've just checked all the snap in connectors and 2 were loose on the top of the stereo(the Toyota blocks) so clicked them in and thought that would be it but still nothing. Really running out of ideas now Any help is really appreciated Link to comment Share on other sites More sharing options...
Pete Posted August 5, 2009 Share Posted August 5, 2009 Are you 100% sure you've reconnected all the connectors? It's easy for one to slip back and get missed. Link to comment Share on other sites More sharing options...
pjavon Posted August 5, 2009 Author Share Posted August 5, 2009 Yes mate, i've removed them from the panel now to make it easier 2 on the heater control panel, the spade connectors for the fag lighter, one for the clock. And the 3 on the top, hazzards odo and one for the display on the door side Link to comment Share on other sites More sharing options...
Lee P Posted August 5, 2009 Share Posted August 5, 2009 Are you 100% sure you've reconnected all the connectors? It's easy for one to slip back and get missed. Or even not be pushed in all the way, double check them. Link to comment Share on other sites More sharing options...
Lee P Posted August 5, 2009 Share Posted August 5, 2009 Yes mate, i've removed them from the panel now to make it easier 2 on the heater control panel, the spade connectors for the fag lighter, one for the clock. And the 3 on the top, hazzards odo and one for the display on the door side What about the plugs that are on top of the stereo mounting cage, are they all in ok? Link to comment Share on other sites More sharing options...
pjavon Posted August 5, 2009 Author Share Posted August 5, 2009 What about the plugs that are on top of the stereo mounting cage, are they all in ok? They were the ones that weren't when i took it apart again and thought that was it. But still the same no heater or clock:( I think i've done 4 times now, even connected the top panel incase they were linked somehow Link to comment Share on other sites More sharing options...
