BLitz Access ECU help - Error codes etc
AMG
I have just come accross a Blitz ECU in my soop which has a few problems at the minute. Dont ask me how it got there as the last one i remember fitting was a mines :blink:
Anyway, i have got a few error codes and was wondering if anyone has experience with them.
Also, to get the error codes, i have to connect the diognostic port as per the VVTI. Does this mean i may have a VVTI ECU?!
Any info appreciated.
The numbers on my ecu are:
PC-23710 T
49564
does anybody know where i could get a list of the error codes for a blitz access? Tried the UK Blitz distributor but they only took it up in 2006. The ECU's were discontinued in 2004.
I have been on the Blitz Japan site but all i can find is the pin out diagram, no error code info.
I'm stuck [sAD][/sAD]
I see you're still struggling with this AMG, I had a go at trying to find a code list for ya, but like the mines search I did, nothing came up.
I've just thought though, It may be worth you getting a stock ECU and running the car for a bit, stay off the loud pedal so you don't get boost/fuel cut, and see if the problems manifest at all. If they do, do the code check again, but this time hopefully, the stock ECU will throw codes out that we can understand.
If the problems don't come about, you know then that your blitz ecu is fubard. Stick with the stock ECU and fit the boost/fuel cut from whifbitz. All in all, if that sorts it, your total expenditure for the repair will be a reasonable £160.
Edited by pistonbroke (see edit history)
Yeah, i think that is what i am goign to do for now. Just a bugger that to find out what is wrong i have to swap the ECU first.
So far the error codes i have on the Blitz are
31 (TPS fault as i simulated this one)
32
63
64
Once i get a standard ECU i will try to sort out a list of caodes and faults to hopefully help in the future.
