wantasupra Posted August 5, 2009 Share Posted August 5, 2009 some wires have come loose on the back of the switch, have contacted Visual Performance to see if they can give information,not had any reply so maybe some one with this switch could take a pic of wires on the back of switch so i can resolder. thanks b Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted August 5, 2009 Share Posted August 5, 2009 I should be able to do that for you later mate, I've just fitted mine and have that switch loose behind the stereo. The stereo is out at the moment so should be able to snap it easy. Quote Link to comment Share on other sites More sharing options...
wantasupra Posted August 5, 2009 Author Share Posted August 5, 2009 thanks, not fun driving without dash lights. b Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted August 6, 2009 Share Posted August 6, 2009 Here ya go Quote Link to comment Share on other sites More sharing options...
wantasupra Posted August 6, 2009 Author Share Posted August 6, 2009 thank you. b Quote Link to comment Share on other sites More sharing options...
The Raven Posted August 6, 2009 Share Posted August 6, 2009 Hmm, I set mine to blue and full power then stuffed it behind the dash. I await mine going wrong now Quote Link to comment Share on other sites More sharing options...
supra steveo Posted August 6, 2009 Share Posted August 6, 2009 Hmm, I set mine to blue and full power then stuffed it behind the dash. I await mine going wrong now same as mine it, havent had a problem yet Quote Link to comment Share on other sites More sharing options...
Lee_e Posted August 6, 2009 Share Posted August 6, 2009 just had a look at those dial kits on visual performance , are they any good ? can anybody recommend them ? im looking at getting myself a set but just wanted to know if you get the bulbs and everything you need with it ? p.s. sorry for the hi-jack Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted August 6, 2009 Share Posted August 6, 2009 I wouldn't know mate, mine are speedhut dials. You won't need bulbs with the indiglo style faces as they are self lit. Here are mine Quote Link to comment Share on other sites More sharing options...
wantasupra Posted August 6, 2009 Author Share Posted August 6, 2009 just had a look at those dial kits on visual performance , are they any good ? can anybody recommend them ? im looking at getting myself a set but just wanted to know if you get the bulbs and everything you need with it ? p.s. sorry for the hi-jack yes there very good. easy to fit.the lights are inside the dials so no need to get or fit bulbs.theres a guide on here. there a doddle to fit. i kept the control panel switch under my dash as i did not need to mess around with the changing from blue to green, i pulled the dash to sort out some other wiring faults with supra. accidently ripped the switch with dash, my error not the kit i would recomend the dials. b Quote Link to comment Share on other sites More sharing options...
catfish man Posted August 6, 2009 Share Posted August 6, 2009 same as mine it, havent had a problem yet i have mine fitted to the plastic steering cover on the bottom near the dash no movement easy to use and tidy just a thought to stop having it moving around:) Quote Link to comment Share on other sites More sharing options...
Lee_e Posted August 6, 2009 Share Posted August 6, 2009 ahh ok then , cheers for the advice , in looking at them now i have an auto but its a facelift. so would i have to contact them for special requirements because by looking at the piccys they only do them for pre facelift big and not the facelift. i have the brushed steel dials at the moment but they arnt giving enough light so think i need to change , but i do like the affect of the steel tho Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted August 6, 2009 Share Posted August 6, 2009 I don't know if anyone else did this, but I connected the power to my dials off the back of the positive and negative feed on the plugs for the main dials. This way they will dim with the main dashboard dimmer. You don't need to use their one!! Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted August 6, 2009 Share Posted August 6, 2009 ahh ok then , cheers for the advice , in looking at them now i have an auto but its a facelift. so would i have to contact them for special requirements because by looking at the piccys they only do them for pre facelift big and not the facelift. i have the brushed steel dials at the moment but they arnt giving enough light so think i need to change , but i do like the affect of the steel tho If you remove the dial cluster, then remove the bulbs, you'll find that they are fitted with a condom thing that makes them dimmer, pull the condom things off and refit the bulbs. Job done, nice and bright. Quote Link to comment Share on other sites More sharing options...
Lee_e Posted August 6, 2009 Share Posted August 6, 2009 ahhh this i wil have to try, but does this apply for non standard bulbs ? the guy before me had blue ones and i think maybe 1 has blown as its not very bright near the 150mph marker and the 2k revs , so thats what makes me think its an ebay jobby. i will contact that company tomorrow for the dials to see if they do for the facelift. and go from there. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted August 6, 2009 Share Posted August 6, 2009 You'll have to work out whether the blue effect is done by a filter on the dials, or whether it has blue bulbs in it. Quote Link to comment Share on other sites More sharing options...
Lee_e Posted August 6, 2009 Share Posted August 6, 2009 mmm im not sure acutally ill have to have a look over the next few days. cheers for the help buddy. Quote Link to comment Share on other sites More sharing options...
