Anyone speak good technical German?
Chris Wilson
I have a pal who speaks good conversational German, but need to check a few technical phrases please.
What would be the correct terms, in German, for the following engine rebuild parts please?
Pistons
Piston ring sets
Con rods
Con rod bearing shells
Crankshaft main bearing shells
Crankshaft thrust washers
Valve spring set (inner and outer)
Head gaskets
Inlet valves
Exhaust valves
Water / oil pump seals
Crankshaft rear oil seal
Thanks for any help here :)
Pistons
Piston ring sets
Con rods
Head gaskets
Inlet valves
Exhaust valves
i will give it my best shot
1) Kolben
2) Kolbenring setzt
3) Schwindeln Sie Ruten
4) Schwindelrutenlager schält
5) Kurbelwelle Traghauptleitung schält
6) Kurbelwellenstoßunterlegscheiben
7) Ventilfedersatz (inner und äußer)
8) Führen Sie Dichtungen
9) Einlassventile
10) Schöpfen Sie Ventile aus
11) Bewässern Sie / Ölpumpenabdichtungen
12) Kurbelwellenhinterseitenölabdichtung
hope this helps, cant say im 100% accurate but give it a go i think you should be ok
Guest Carsten
Here you go :)
Pistons - Kolben
Piston ring sets - Kolbenringe (set/paar)
Con rods - Pleul
Con rod bearing shells - Pleul-Lagerschalen
Crankshaft main bearing shells - Hauptlager (der Kurbelwelle)
Crankshaft thrust washers - Druckringe (der Kurbelwelle)
Valve spring set (inner and outer) - Ventilfedern
Head gaskets - Zylinderkopfdichtung (ZKD)
Inlet valves - Einlassventile
Exhaust valves - Abgas/auslass Ventil
Water / oil pump seals - Wasser / Ölpumpen Dichtungen
Crankshaft rear oil seal - Kurbelwellendichtung für Öl (hinten)
If you need any more help just ask.
wow. Just have to figure out the old chestnut of finding the best translation. My german is too poor to know any of those, funnily, although german is an extremely erotic language I'm liking the english tech terms a lot better.
Carl, stop posting this rubish or I will make you stop posting it.
Last warning.
My technical German stops at "Die Bremsen ist Kaputt" which I put to good use the first time I went to the 'ring and had managed to nadge the rear calipers :D
It didn't get me very far!
Still the guy who was with us who had worked in Germany for Ford for 3 years only managed to come up with "Sprachen sie English?", so I was virtually fluent in comparison.
This is what I settled with and have sent. Thanks fellas, great spirit :)
Sent in German and English.
Hallo László
Können Sie mir einen Preis und eine Verfügbarkeit für die folgenden Teile für eine Mugen MF-308 F3000 Motornummer MF 1117 geben bitte
Kolben x 8
Kolbenring x 9
Pleuelstange x 8 (Größe 126mm lang, 50 Millimeter-Kurbelwellenendebohrung, 21 Millimeter-Kolbenbolzen gebohrt)
Einlassventile x 10
Auslassventile x 3
Ventilfedern (inneres und äußeres) x 32
Zylinderkopftdichtung x 2 (ein Paar, werden sie übergeben, links und rechts)
hintere Kurbelwellendichtung
Pleuellagerschalen für 46 Millimeter Kolbenbolzen
Hauptlagerschalen 56 Millimeter-reizbare Größe
Öl- und Wasserpumpendichtungen (zwischen den Pumpenhälften).
Für Erklärung, wenn Sie mir ein Bild der Teile schicke
mit freundlichen Grüßen
Chris Wilson mailto:[email protected]
P.S Ich kann selbst vereinbaren, damit die Teile aufgehoben werden können, abhängiger auf dem Preis des Postens und des Pakets.
Hallo László
Kolben x 8
Kolbenring x 9
Einlassventile x 10
Auslassventile x 3
Fancy translating that into English for us? Some of us don't speak German you know! :p
Hello László
Please can you give me a price and availability for the following parts
for a Mugen MF-308 F3000 engine number MF 1117
pistons x 8
piston ring sets x 9
con rods x 8 (size 126mm long, 50 mm big end bore, 21 mm piston pin bore)
inlet valves x 10
exhaust valves x 3
valve springs (inner and outer) x 32
head gaskets x 2 (a pair, they are handed)
rear crankshaft seal
con rod bearings for 46 mm crank pin size
main crankshaft bearings for 56 mm crank size
Oil and water pump seals (between the pump halves).
For clarification if you can send me a picture of the parts.
Best regards,
P.S I can arrange for the parts to be picked up dependent on the price of the post and packaging.
Btw Chris. Dont use Bigcol´s translation ^^
Its nonsense. Typical translation mashine fail
well i am sorry:blink:, next time anyone asks for help i wont bother my arse trying to help them, honestly you try and help someone out etc etc etc :rolleyes:
and by the way its MACHINE not mashine (well according to my typical translation machine);)
BTW. sorry Chris just used my german translator thought it would help
1) Kolben
2) Kolbenring setzt
9) Einlassventile
I was going to tell you the same. I am from Germany but didn't know the correct Translation for your parts as I am not Technicaly minded like that, but Bigcols Translations are totally useless unless you want to give the Garage you call for the Parts a good laugh, lol.
No offence Col xx
Guest Carsten
Bigcol honestly i didnt want to offend you :)
It was just a information for Chris :)
Mayb me english sounds a bit too harsh :D
:D you didnt mate i was being sarcastic (its one of the only few things in life i am actually very good at being)
