Guest Aerosmith Posted August 3, 2009 Share Posted August 3, 2009 similar prob like [caseys, page 1]mine come on for a few seconds when turning left, I have tried only turning right, the problem goes away, that creates a bigger problem as I end up back home again after only being out for 2 mins,[ JUST HAD NEW CALIPERS FITTED ON FRONT ON FRIDAY ] ,the lights which illuminate on the dash are activated when the handbrake is applied, why are they coming on when driving.[turning left] any suggestions much appreciated thanks. Quote Link to comment Share on other sites More sharing options...
gordy07 Posted August 3, 2009 Share Posted August 3, 2009 Brake fluid level? Quote Link to comment Share on other sites More sharing options...
caseys Posted August 3, 2009 Share Posted August 3, 2009 When you say turning left you do mean turning left and not just whilst the wheels on left lock whilst stationary or anything? I'd say break fluid for you. Most of the threads I was searching through the other night were all for temporarily lighting up of the light whilst the car was moving. My light issue was when stationary without even touching the steering wheel. Maybe you've lost a bit of brake fluid with the new calipers being fitted? I assume they've bled them all correctly too? Quote Link to comment Share on other sites More sharing options...
dukenukem Posted August 3, 2009 Share Posted August 3, 2009 Left indicator bulb? Quote Link to comment Share on other sites More sharing options...
Guest Aerosmith Posted August 4, 2009 Share Posted August 4, 2009 (edited) When you say turning left you do mean turning left and not just whilst the wheels on left lock whilst stationary or anything? I'd say break fluid for you. Most of the threads I was searching through the other night were all for temporarily lighting up of the light whilst the car was moving. My light issue was when stationary without even touching the steering wheel. Maybe you've lost a bit of brake fluid with the new calipers being fitted? I assume they've bled them all correctly too? thanks for your quick replies, I'll let you know how I get on with that,much appreciated. Edited August 4, 2009 by Aerosmith (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest Aerosmith Posted August 4, 2009 Share Posted August 4, 2009 why did I not think of that? stupid me haha, I'm on the case. Quote Link to comment Share on other sites More sharing options...
Guest Aerosmith Posted August 4, 2009 Share Posted August 4, 2009 Brake fluid level? yeah, this seems to be the general opinion, I'm going to try it today, and see how I get on. Thanks for your input. Quote Link to comment Share on other sites More sharing options...
caseys Posted August 4, 2009 Share Posted August 4, 2009 Generally if you've lost an indicator at the front the relay will click at twice the speed it does normally. So unless your left indicator on the dash is a lot quicker than the right it's not an indicator bulb. Quote Link to comment Share on other sites More sharing options...
Guest Aerosmith Posted August 5, 2009 Share Posted August 5, 2009 yep, bingo, brake fluid level, bought some today didn't even add a capfull, problem gone... once again a big THANKYOU for your help. Quote Link to comment Share on other sites More sharing options...
Guest Aerosmith Posted August 5, 2009 Share Posted August 5, 2009 thanks for your quick replies, I'll let you know how I get on with that,much appreciated. yep ,bingo, brake fluid ,problem gone ,didn't even add a capfull,a big THANKYOU for your help cheers . Quote Link to comment Share on other sites More sharing options...
Guest Aerosmith Posted August 5, 2009 Share Posted August 5, 2009 thanks for your quick replies, I'll let you know how I get on with that,much appreciated. yep, bingo, brake fluid, didn't even add a capfull, problem gone, a big THANKYOU for your help cheers Quote Link to comment Share on other sites More sharing options...
Guest Aerosmith Posted August 5, 2009 Share Posted August 5, 2009 yep, bingo, brake fluid, didn't even add a capfull, a big THANKYOU for your help cheers Quote Link to comment Share on other sites More sharing options...
caseys Posted August 5, 2009 Share Posted August 5, 2009 That's a lot of thanks Glad it's a simple and easy fix The forum is a wealth of knowledge isn't it? Quote Link to comment Share on other sites More sharing options...
