no boost from tubby 1
gavin.starr
after loosing boost on my second turbo i decided to buy a new to me set from michel lane on friday. (there was no ceramic left on the turbo at all when i inspected it, hence th loss of boost in tubby 2)
i have grafted my arse off this weekend to get them on, now that they are on i have no boost coming in from the first turbo:banghead:, am i now right in thinking that my vsv's may have gone as well or would that not be the case.
what do i need to be taking a look at to solve the mistery.
gav
oh and another point i wanted to add is that i get no boost from either number 1 or 2 in first gear, say i set off from a set of lights it travels all the way through first gear with nothing,
once i get into second gear there is nothing from turbo 1 and then a kick comes about 4500 rpm from the second and so on through the rest of the gears
just checked them all an found one to be faulty / caput :) so hopefully this is th cause of the problem.
does any one on here have a working second hand set or know some where that i can buy new.
are these valves cheap or expensive if there not oo bad a might replace the lot.
cheers fella
gav
