dwayne Posted October 11, 2010 Share Posted October 11, 2010 no pausing at any time? Quote Link to comment Share on other sites More sharing options...
Nic Posted October 11, 2010 Share Posted October 11, 2010 is it just the rotor arm to replace? no other bits needed? am ordering few other parts so will do it all in one go? is it an easy diy job? You could try renewing these. 19101-70020 Toyota Distributor Cap - 2JZ-GE 19102-46011 Toyota Rotor Arm - 2JZ-GE 90919-21521 Toyota Spark Plug Lead Set - 2JZ-GE Quote Link to comment Share on other sites More sharing options...
fizzle Posted October 11, 2010 Author Share Posted October 11, 2010 cheers nic... i want some blue leads if i swap them, can u recommend any? no pauses just flashes dwayne.. Quote Link to comment Share on other sites More sharing options...
Nic Posted October 11, 2010 Share Posted October 11, 2010 The Sun Auto Hot Wires are very good, but they are expensive. Quote Link to comment Share on other sites More sharing options...
dwayne Posted October 11, 2010 Share Posted October 11, 2010 pretty sure continual flashing means no errors so hopefully nothing too serious mate Quote Link to comment Share on other sites More sharing options...
David P Posted October 11, 2010 Share Posted October 11, 2010 I have those Nology Hot Wires on mine, I chose red, but they are available in blue too. MVP Motorsports stock them. Quote Link to comment Share on other sites More sharing options...
fizzle Posted October 11, 2010 Author Share Posted October 11, 2010 pretty sure continual flashing means no errors so hopefully nothing too serious mate result, although its not doing the chugging at the mo... usually starts after 5 mins driving so will try again when it does it! cheers m8 Quote Link to comment Share on other sites More sharing options...
Robzki Posted October 11, 2010 Share Posted October 11, 2010 From what I've read here it sounds normal for an NA Seriously, As Nic said, If you don't know when things have been changed I'd start with dizzy cap, leads/plugs and rotor arm. Least you aren't wasting money on non service items Quote Link to comment Share on other sites More sharing options...
fizzle Posted October 11, 2010 Author Share Posted October 11, 2010 (edited) just ordered parts from steve manley as well as the starter motor refurb kit. Only £48 delivered!! didn't get the leads as want to find some blue ones. just waiting on reply from mvp on those nology leads! might as well get the plugs done as well seems pointless doing the rest and not them... stock or aftermarket? also had the battery tested and that's all good.. Edited October 11, 2010 by fizzle (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted October 11, 2010 Share Posted October 11, 2010 When did you last change the fuel filter? Quote Link to comment Share on other sites More sharing options...
fizzle Posted October 11, 2010 Author Share Posted October 11, 2010 When did you last change the fuel filter? last summer.. Quote Link to comment Share on other sites More sharing options...
