fizzle Posted August 3, 2009 Share Posted August 3, 2009 (edited) sorry not an invite to a beer drinking comp... when i apply the gas the car chuggs and splutters, (sounds like a blockage in fuel pipe ) this only occurs whilst engine is cold, once warmed up its fine.. i tried the STP injector cleaner, and also a fuel cleaner but to no avail. i've had 2 m8's look at it one thinks could be o2 sensors the other says the temp sensor.. has anyone else had this problem?, where are the said sensors located? how much to replace? its a 94 n/a. thanks Edited August 3, 2009 by fizzle (see edit history) Quote Link to comment Share on other sites More sharing options...
fizzle Posted August 5, 2009 Author Share Posted August 5, 2009 any help??? Quote Link to comment Share on other sites More sharing options...
caseys Posted August 5, 2009 Share Posted August 5, 2009 The linked picture taken by Ian C shows one of the o2 sensor positions http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13944&d=1112559002 thought that is for a TT and I don't know where the NA setup differs. I know they're not alike though Not sure on the temp sensor he's referring to though sorry. Quote Link to comment Share on other sites More sharing options...
miko_supra Posted August 5, 2009 Share Posted August 5, 2009 Tried a simple ECU reset yet? Quote Link to comment Share on other sites More sharing options...
fizzle Posted August 5, 2009 Author Share Posted August 5, 2009 Tried a simple ECU reset yet? no how is this done? any risks? Quote Link to comment Share on other sites More sharing options...
dukenukem Posted August 5, 2009 Share Posted August 5, 2009 no how is this done? any risks? Just disconnect the battery for at least a minute. Quote Link to comment Share on other sites More sharing options...
ilicos Posted August 5, 2009 Share Posted August 5, 2009 Did you wash the engine? Quote Link to comment Share on other sites More sharing options...
fizzle Posted August 6, 2009 Author Share Posted August 6, 2009 no havent washed engine! will try reset tonight if it stops raining.. thanks Quote Link to comment Share on other sites More sharing options...
fizzle Posted August 9, 2009 Author Share Posted August 9, 2009 disconnected battery as instructed... Bingo! all good now guys thanks:thumbs: Quote Link to comment Share on other sites More sharing options...
fizzle Posted October 6, 2010 Author Share Posted October 6, 2010 right this problem has returned tried the reset but still happening, doesnt seem to clear up when i drive either, gave it a bit of welly to see if it was just a blockage in fuel pipes etc but problem persists... just seems to be problem after problem atm... gettin very fed up with supra ownership! any ideas guys? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted October 6, 2010 Share Posted October 6, 2010 Take it you've checked the condition of the dizzy cap, arm and HT leads? Quote Link to comment Share on other sites More sharing options...
fizzle Posted October 6, 2010 Author Share Posted October 6, 2010 Take it you've checked the condition of the dizzy cap, arm and HT leads? all appear to be present and correct... Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted October 6, 2010 Share Posted October 6, 2010 Lol not if theyre fitted, does the rotor arm look burnt, evidence of arcing and stuff inside the dizzy cap? When did you last change them? Quote Link to comment Share on other sites More sharing options...
fizzle Posted October 6, 2010 Author Share Posted October 6, 2010 sorry bare with me, i'm learning as i go.... the dizzy cap is the bit all the ht leads fit into, correct? shall i take that apart and look for signs of burning? where is the rotor arm located? not sure if/when they have been changed? i haven't done it in the 3years i owned it! thanks for your help! Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted October 6, 2010 Share Posted October 6, 2010 sorry bare with me, i'm learning as i go.... the dizzy cap is the bit all the ht leads fit into, correct? shall i take that apart and look for signs of burning? where is the rotor arm located? not sure if/when they have been changed? i haven't done it in the 3years i owned it! thanks for your help! inside the cap,they are cheap enuf from toyota.ive had a fiew engines where the arm was burnt away. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted October 6, 2010 Share Posted October 6, 2010 Maybe check the condition of the air filter: if it's old it might be starving the engine of air. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted October 6, 2010 Share Posted October 6, 2010 sorry bare with me, i'm learning as i go.... the dizzy cap is the bit all the ht leads fit into, correct? shall i take that apart and look for signs of burning? where is the rotor arm located? not sure if/when they have been changed? i haven't done it in the 3years i owned it! thanks for your help! Yes the bit where the HT leads go is the distributer cap and inside that is the rotor arm. If its not been changed in 3 years you'd do well to replace it, will probably transform your car lol Quote Link to comment Share on other sites More sharing options...
fizzle Posted October 11, 2010 Author Share Posted October 11, 2010 Yes the bit where the HT leads go is the distributer cap and inside that is the rotor arm. If its not been changed in 3 years you'd do well to replace it, will probably transform your car lol is it just the rotor arm to replace? no other bits needed? am ordering few other parts so will do it all in one go? is it an easy diy job? thanks for the help guys!! Quote Link to comment Share on other sites More sharing options...
fizzle Posted October 11, 2010 Author Share Posted October 11, 2010 Maybe check the condition of the air filter: if it's old it might be starving the engine of air. hks panel filter is in as new condition. Quote Link to comment Share on other sites More sharing options...
Robzki Posted October 11, 2010 Share Posted October 11, 2010 Not too adept with the NA, but have/can you check error codes? Quote Link to comment Share on other sites More sharing options...
fizzle Posted October 11, 2010 Author Share Posted October 11, 2010 Not too adept with the NA, but have/can you check error codes? no and have no idea how!! Quote Link to comment Share on other sites More sharing options...
dwayne Posted October 11, 2010 Share Posted October 11, 2010 bridge E1 and TE1 with a paperclip in the diag port but you need the ignition on and then check how many times the engine light flashes. it'll flash then pause for the first digit then flash again for the second (i think there's a guide somewhere on this) here it is http://www.mkivsupra.net/vbb/showthread.php?t=35920&highlight=check+engine+code Quote Link to comment Share on other sites More sharing options...
fizzle Posted October 11, 2010 Author Share Posted October 11, 2010 just removed dizzy cap, and everything looks clean with no signs of wear or burning! Quote Link to comment Share on other sites More sharing options...
Robzki Posted October 11, 2010 Share Posted October 11, 2010 error codes? Quote Link to comment Share on other sites More sharing options...
fizzle Posted October 11, 2010 Author Share Posted October 11, 2010 (edited) bridge E1 and TE1 with a paperclip in the diag port but you need the ignition on and then check how many times the engine light flashes. it'll flash then pause for the first digit then flash again for the second (i think there's a guide somewhere on this) here it is http://www.mkivsupra.net/vbb/showthread.php?t=35920&highlight=check+engine+code did this but engine light just flashes continuosly Edited October 11, 2010 by fizzle (see edit history) Quote Link to comment Share on other sites More sharing options...
