penguin Posted August 2, 2009 Share Posted August 2, 2009 DON'T!! the diesel fuel pump just "went" on mine last night - got quoted £700 for a refurbed unit or a whole lot more for a new one Link to comment Share on other sites More sharing options...
Konrad Posted August 2, 2009 Share Posted August 2, 2009 What Vauxhall is it? I might help with pump as I have one for sale from working 2.2 DTi engine. Link to comment Share on other sites More sharing options...
Kearney Posted August 3, 2009 Share Posted August 3, 2009 Buy an opel instead Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted August 3, 2009 Share Posted August 3, 2009 I have a good one off a 2.0 dtl Link to comment Share on other sites More sharing options...
penguin Posted August 3, 2009 Author Share Posted August 3, 2009 its a 99 vectra dti ..... the pump is encoded and guess who you have to go to to get it replaced getting another pump will still require the ecu to be programmed Link to comment Share on other sites More sharing options...
absz Posted August 3, 2009 Share Posted August 3, 2009 very common fault on these has been for a few years now. might work out cheaper getting a used pump including immbolizer unit/key chip. its the circuit inside the pump that fails. Link to comment Share on other sites More sharing options...
penguin Posted August 3, 2009 Author Share Posted August 3, 2009 is this also a common fault on the newer vectras? i've been offered a 2003 model Link to comment Share on other sites More sharing options...
absz Posted August 3, 2009 Share Posted August 3, 2009 i have seen a few 2003/05 ones playing up but not as much as the earlier models. won't put me of buying one as the prices have come down alot. Link to comment Share on other sites More sharing options...
L33 Posted August 3, 2009 Share Posted August 3, 2009 or get a holden as on top gear last night Link to comment Share on other sites More sharing options...
Konrad Posted August 3, 2009 Share Posted August 3, 2009 It was quite common on 2.0 DTI engines, with Bosch pumps (symbol was VP44 or something similiar). 2003 Vectra with 2.2 DTI engine and you should be fine, those got newer pump of different type and they are not prone to failure. Link to comment Share on other sites More sharing options...
Pete Posted August 4, 2009 Share Posted August 4, 2009 DON'T!! I could've saved you the trouble and told you this years ago...in fact, search hard enough on here and you'll see that I did. Repeatedly. Link to comment Share on other sites More sharing options...
