compression test ??
eyefi
im trying to do a compression test and im having trouble getting the car to stop spraying fuel.
the manual says to "disconnect the camshaft position sensor connectors and disconnect the solenoid resistor sensor connector". i cant get the cam position connections off cos there's a big bloody throttle body in the way which is very hot, and i cant find the solenoid resistor sensor connector. can anyone help me out? or is there any other way to stop it spraying fuel while the engine spins.
its a jspec
cheers,
did the test by pulling efi fuse 1.
i was suprised by the results:-
1. 178
2. 176
3. 175
4. 176
5. 175
6. 180
the book spec is 150 psi (ish) or more with no less than 14 psi difference.
it takes the piss really, a 10 yr old high performance car still pulling numbers like that. well done toyota.
