Help: what's been ripped off my car?
lust2luv
As above, but if you have the 2nd cat in then isn't there now a hole in it where this was?
No the temp sensor goes into the first cat.
It will work perfectly fine without it connected, mine wasnt connected for years and never had a problem and im fully decat.
Just tie it out the way and all will be fine
D'oh! I was thinking of the Soarer, which only has the second cat so the sensor is at the end of it. :imsorry:
Does makes more sense, I was wondering how it managed to get pulled out without eating 2 inches off the bottom of the car first!! :D
If it is an n/a I think it is called an exhaust temperature sensor, I lost the tin shield off of mine over a bump and at first I was sure what I could see in exactly the same place as in your picture was the 'Lambada' ! sensor. Turns out there are 2 of them but they are both up on the manifold and the one at the bottom is a heat sensor
