lust2luv Posted July 31, 2009 Share Posted July 31, 2009 Hi guys Haven't posted for ages, just popped by for a little advice. What have the newly installed exit ramps at my works car park ripped off my car? (see attached pic) Many thanks is advance. Link to comment Share on other sites More sharing options...
Wez Posted July 31, 2009 Share Posted July 31, 2009 Looks like stock JDM cat temp sensor to me. Link to comment Share on other sites More sharing options...
pedrosixfour Posted July 31, 2009 Share Posted July 31, 2009 Looks like stock JDM cat temp sensor to me. I second that Link to comment Share on other sites More sharing options...
Guest Garfy Posted July 31, 2009 Share Posted July 31, 2009 yep, do you have a de-cat? it could be that it is no longer required and was tied up out of the way Link to comment Share on other sites More sharing options...
lust2luv Posted July 31, 2009 Author Share Posted July 31, 2009 First (downpipe) cat is out, second is in at the moment - is it essential, or would it be okay just to cable tie it out the way? (may have been that way previously) Cheers Link to comment Share on other sites More sharing options...
Guest Garfy Posted July 31, 2009 Share Posted July 31, 2009 I pretty certain it will be fine Link to comment Share on other sites More sharing options...
stevie_b Posted July 31, 2009 Share Posted July 31, 2009 Temp sensor or O2 sensor I guess. Link to comment Share on other sites More sharing options...
edge Posted July 31, 2009 Share Posted July 31, 2009 Cat 1 temp sensor. Just tie it out of the way. Link to comment Share on other sites More sharing options...
Hermit Posted July 31, 2009 Share Posted July 31, 2009 As above, but if you have the 2nd cat in then isn't there now a hole in it where this was? Link to comment Share on other sites More sharing options...
Al Massey Posted July 31, 2009 Share Posted July 31, 2009 As above, but if you have the 2nd cat in then isn't there now a hole in it where this was? No the temp sensor goes into the first cat. It will work perfectly fine without it connected, mine wasnt connected for years and never had a problem and im fully decat. Just tie it out the way and all will be fine Link to comment Share on other sites More sharing options...
Hermit Posted July 31, 2009 Share Posted July 31, 2009 No the temp sensor goes into the first cat. D'oh! I was thinking of the Soarer, which only has the second cat so the sensor is at the end of it. Does makes more sense, I was wondering how it managed to get pulled out without eating 2 inches off the bottom of the car first!! Link to comment Share on other sites More sharing options...
Keefred Posted July 31, 2009 Share Posted July 31, 2009 If it is an n/a I think it is called an exhaust temperature sensor, I lost the tin shield off of mine over a bump and at first I was sure what I could see in exactly the same place as in your picture was the 'Lambada' ! sensor. Turns out there are 2 of them but they are both up on the manifold and the one at the bottom is a heat sensor Link to comment Share on other sites More sharing options...
Homer Posted July 31, 2009 Share Posted July 31, 2009 Cat 1 temp sensor. Just tie it out of the way. Bingo. Or cut it off Link to comment Share on other sites More sharing options...
mikeyb10supra Posted August 1, 2009 Share Posted August 1, 2009 Its fine although you might want an EGT gauge to keep an eye on things Link to comment Share on other sites More sharing options...
lust2luv Posted August 2, 2009 Author Share Posted August 2, 2009 Cheers guys, you're amazing as always. I'm gonna cable tie it out of the way. Link to comment Share on other sites More sharing options...
hiten55 Posted August 2, 2009 Share Posted August 2, 2009 make sure the ramp doesnt rip the cable tie off Link to comment Share on other sites More sharing options...
benkei Posted August 2, 2009 Share Posted August 2, 2009 make sure the ramp doesnt rip the cable tie off Link to comment Share on other sites More sharing options...
