motorbike question
brettjones
maybe a daft question but has the tank gone onto reserve and you have the fuel switch on normal
is there a kill switch on the handle bars, is it switched to run,
I know these are daft but the amount of times I did this myself it is worth asking :)
no reserve on the tank and no kill switch just on the key
Guest bennyessex
Did it heat up before it cut out? Whats the milage?
Sveral things to check as process of elimination. Check the plug for oil or moisture, check the filter for dirt etc. Check the fuel filter if there is one for blockage.
Well got the bike to my mates garage and its piston ring very low on compression and the clutch is slipping.Looked at the digital dash at max speed and the boy has hit over 60 so he must have been on full beans.Thanks for everyones input.Its in my mates safe hands now just have to put up with a pi----f 16 year old:rolleyes:
