Steve Posted November 9, 2009 Author Share Posted November 9, 2009 Link to comment Share on other sites More sharing options...
TLicense Posted November 16, 2009 Share Posted November 16, 2009 (edited) Did a bit more work over the weekend. CC'd the engine and the head. I didn't get any pics of that, but those interested can see some in the build thread for my engine. I then fitted the freshly cleaned up engine mounts and water neck. Ignore the 'wet' marks, that's just where I'd cleaned the grit media off:- Then fitted the ARP head studs and gasket:- And then fitted the head, which I believe Steve has had built and ported by Whifbitz:- Artistic shot with the cam-covers temporarily fitted:- Tomorrow I'll finish fitting the camshafts and if all goes well hopefully get the flywheel fitted. Then it's all good to go! Edited February 8, 2010 by Steve (see edit history) Link to comment Share on other sites More sharing options...
Steve Posted November 16, 2009 Author Share Posted November 16, 2009 Hopefully see you Friday then mate Link to comment Share on other sites More sharing options...
TLicense Posted November 19, 2009 Share Posted November 19, 2009 (edited) OK camshafts fitted:- Then the timing belt and the no.1 timing belt cover:- Then the crank pulley. You can see where the balancer has removed some material:- Then it's just a case of fitting the lining up the timing marks and fitting the belt. Here's the new belt tensioner. It came with the little pin, it reminds me of a hand grenade :- And that's it pretty much all done bar a few odds and sods and fitting the flywheel / clutch. Edited February 8, 2010 by Steve (see edit history) Link to comment Share on other sites More sharing options...
Steve Posted November 19, 2009 Author Share Posted November 19, 2009 So close now Link to comment Share on other sites More sharing options...
MarkR Posted November 19, 2009 Share Posted November 19, 2009 So close now You must be as excited as I am. I get mine next Tuesday Link to comment Share on other sites More sharing options...
Steve Posted November 19, 2009 Author Share Posted November 19, 2009 I can't wait to get it back. If all goes to plan, it will be back in the car over the weekend to Link to comment Share on other sites More sharing options...
MarkR Posted November 19, 2009 Share Posted November 19, 2009 I can't wait to get it back. If all goes to plan, it will be back in the car over the weekend to Awesome... some video would be great Link to comment Share on other sites More sharing options...
Steve Posted November 19, 2009 Author Share Posted November 19, 2009 Now I didn't say running Link to comment Share on other sites More sharing options...
MarkR Posted November 19, 2009 Share Posted November 19, 2009 Why not, what's wrong with you pull finger!! Link to comment Share on other sites More sharing options...
Steve Posted November 19, 2009 Author Share Posted November 19, 2009 There shall be photos of installation and me cutting my hands to bits i'm sure I will definitely get a video of first startup! Link to comment Share on other sites More sharing options...
Steve Posted November 28, 2009 Author Share Posted November 28, 2009 Well I have the engine back now after picking it up last night from Tony. Today I managed to get the clutch fitted, gearbox fitted, exhaust manifold fitted, turbo exhaust housing, wastegate, water elbow, turbo oil drain pipe, oil feed pipe and blocked of the old turbo water feeds. Didn't manage to get it dropped into the car today as it was getting dark so that will be done tomorrow and will see what else I can get done. I do have some pictures but haven't got the lead to get them off of the camera, so will post them next week. Link to comment Share on other sites More sharing options...
JamieP Posted November 28, 2009 Share Posted November 28, 2009 Not long now mate, bet you're itching to get driving it again. Link to comment Share on other sites More sharing options...
Steve Posted November 28, 2009 Author Share Posted November 28, 2009 Not long now mate, bet you're itching to get driving it again. Yeah definitely am mate, I have a feeling I will get the running in miles done pretty quickly Link to comment Share on other sites More sharing options...
Steve Posted November 29, 2009 Author Share Posted November 29, 2009 Well the engine is back in the car, got all the water pipes plumbed in, the harness back in the correct position, alternator, PS pump, aircon pump, radiator all fitted and the lower intake runners fitted. Just need to fit the plenum, injectors, fuel rail, turbo and i/c pipework then should be all good to go. Link to comment Share on other sites More sharing options...
Kirk Posted November 29, 2009 Share Posted November 29, 2009 nice work mate.. bet you cant wait. Id be on it now until it was finished curious though as im not that clued up on the balancing side of things, im presumming the 'drilled' holes in the crank pulley is a result of the balancing process? Link to comment Share on other sites More sharing options...
Steve Posted November 29, 2009 Author Share Posted November 29, 2009 nice work mate.. bet you cant wait. Id be on it now until it was finished curious though as im not that clued up on the balancing side of things, im presumming the 'drilled' holes in the crank pulley is a result of the balancing process? There are 4 holes which were done by Toyota (or whoever manufacturers it) then the other hole on its own was done by the balancers. The pulley was connected to the crank and the clutch, then were all balanced together. Link to comment Share on other sites More sharing options...
sdistc Posted November 29, 2009 Share Posted November 29, 2009 Fantastic work! Love the photographic documentation, and the attention to detail. Link to comment Share on other sites More sharing options...
TLicense Posted November 29, 2009 Share Posted November 29, 2009 Well the engine is back in the car, got all the water pipes plumbed in, the harness back in the correct position, alternator, PS pump, aircon pump, radiator all fitted and the lower intake runners fitted. Just need to fit the plenum, injectors, fuel rail, turbo and i/c pipework then should be all good to go. Good work! Link to comment Share on other sites More sharing options...
Steve Posted November 29, 2009 Author Share Posted November 29, 2009 Good work! I was gonna carry on but was getting moaned at Link to comment Share on other sites More sharing options...
TLicense Posted November 29, 2009 Share Posted November 29, 2009 lol I know exactly what you mean! Link to comment Share on other sites More sharing options...
Steve Posted November 29, 2009 Author Share Posted November 29, 2009 I will drop the engine lift down to your work to tomorrow mate if that's ok? Link to comment Share on other sites More sharing options...
TLicense Posted November 29, 2009 Share Posted November 29, 2009 Link to comment Share on other sites More sharing options...
Steve Posted November 30, 2009 Author Share Posted November 30, 2009 (edited) This is the engine when I got it back from picking it up from Tony on Friday evening. The first thing I did was to fit the clutch. The new Southbend Stage 3 clutch plate. and the clutch cover, you can see the area where the cover had some material removed where it was balanced. Here you can see the paint mark I had to line up as this was balanced with the crank. Getting the plate lined up was made easy with the tool supplied with the new clutch The clutch cover was then bolted up and torqued as per the Toyota manual. I then fitted the gearbox and torqued the bolts up. The starter motor then got fitted but didn't get a picture of that. I then refitted the exhaust manifold, it so much easier fitting it now then when the engine is back in the car. I also bolted on the new Borg Warner turbo exhaust housing and the oil drain pipe. This is the 1.0 a/r twinscroll housing. You can see where the 3" vband fitting was welded on. I took some pictures of the old T67 .68 a/r housing to show the size difference and the twin/single scroll. Edited February 8, 2010 by Steve (see edit history) Link to comment Share on other sites More sharing options...
Steve Posted November 30, 2009 Author Share Posted November 30, 2009 (edited) I had to block off the old water feeds as they are no longer required with this turbo. After fitting a few other little pieces like the water feed elbow and fitting some new jubilee clips to various pipes it was ready to refit the engine back into the car. After a little swearing it was back in the car I could then re route the electrics back into their correct places, fit the a/c pump, PS pump, alternator, new aux belt, radiator, fan, fan shroud and the inlet runner. That was what I managed over the weekend and will hopefully get the rest done over a few evenings this week and Saturday. Edited February 8, 2010 by Steve (see edit history) Link to comment Share on other sites More sharing options...
