Ryan.G Posted July 26, 2009 Share Posted July 26, 2009 Take off plate and relocation plate with fittings. £40 Link to comment Share on other sites More sharing options...
Ryan.G Posted August 9, 2009 Author Share Posted August 9, 2009 Only handbrake now Link to comment Share on other sites More sharing options...
Andy-No-Knee Posted August 14, 2009 Share Posted August 14, 2009 Hi Ryan, Got the bits thanks. Quick question, the block with the bracket on - it this to go to engine side or filter side? Looking at it I would have thought it would be filter side, but it also has the threads in for sensors (or is it ok to have the oil press and temp so far from the engine block?). Ta! Link to comment Share on other sites More sharing options...
ajazyasin Posted August 14, 2009 Share Posted August 14, 2009 the bracket one is for the filter. Link to comment Share on other sites More sharing options...
Ryan.G Posted August 14, 2009 Author Share Posted August 14, 2009 Hi Ryan, Got the bits thanks. Quick question, the block with the bracket on - it this to go to engine side or filter side? Looking at it I would have thought it would be filter side, but it also has the threads in for sensors (or is it ok to have the oil press and temp so far from the engine block?). Ta! The bracket one is for the filter side and the reason the sensors are mounted there is because it stops any mechnical vibrations from the engine killing the sensors Ryan Link to comment Share on other sites More sharing options...
Andy-No-Knee Posted August 14, 2009 Share Posted August 14, 2009 The bracket one is for the filter side and the reason the sensors are mounted there is because it stops any mechnical vibrations from the engine killing the sensors Ryan Ahhhh!!! I knew there had to be a reason, just one I didnt know!!! Thanks!!! Link to comment Share on other sites More sharing options...
